Old 3/21/10, 9:33 PM
Default tempered glass
What year did tempered glass make it into code?
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/21/10, 9:42 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: tempered glass
UBC "64", revised in "79", revised in "82" and again in "91". What area of the home are you referring to.
www.MauiHomeInspections.com
Old 3/21/10, 10:59 PM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
I know my inspecton for monday has a bedroom window thats very low to the floor and has no sg and I would also like to know the yr on this anyone got it?
was built in 79
Old 3/21/10, 11:18 PM
Unmoderated Guest
"64" was the less than 18in above the floor/larger than 6 sq.ft rule. In "79" they inserted exceptions for the 18 in rule that are protected by guard rail, hand rail or other approved barrier.
Old 3/21/10, 11:43 PM
James H. Bushart's Avatar
The code does not call for tempered glass. It calls for "safety glass" that can be either tempered, laminated, or an approved plastic.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 3/22/10, 7:53 AM
It is an older home I called it out as a safety upgrade, due to door and steps. Was just curious as to the date.
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Old 3/22/10, 12:13 PM
Unmoderated Guest
The first safety glass was a fine wire mesh embedded in the glass.
Old 3/22/10, 2:19 PM
Jeffrey R. Pope's Avatar
The glass in your picture would be required to be tempered/safety glass based on current standards. There is also a requirement for a handrail in that picture, and the door opens the wrong way. . . How about lighting?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Tempered glass rules for a stairwell? jfunderburk Interior Inspections 8 6/23/09 12:26 AM
Tempered glass wsiegel Interior Inspections 7 2/9/09 1:21 AM
Attic access ladders and tempered glass moliver General Inspection Discussion 4 10/13/08 12:49 PM
