Old 6/26/08, 12:02 AM
James H. Bushart's Avatar
Default Three Decks Collapse in One Weekend
http://www.kirotv.com/mostpopular/16686572/detail.html
http://cbs3.com/local/deck.collapse.evesham.2.754419.html
http://www.wpri.com/global/story.asp?s=8540412
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 6/26/08, 12:17 AM
Christopher Currins's Avatar
Default Re: Three Decks Collapse in One Weekend
Looks like all 3 had the same problem, not attached to the building properly. Now the inspectors are investigating. A day late and a dollar short.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 6/26/08, 9:03 PM
Peter C. Russell's Avatar
Now this is what I call a deck...... or two!!
Old 7/4/08, 4:06 AM
Tim Spargo's Avatar
We're used to 6x posts and 2x10 min for decks. Looks like 4 x 4 and 2x8 at most. Course it's a ways off.
The upper decks... I'm not accustomed to see cantalevered joist's anymore. They still do that there? Been a few decks and apartment walkways collapse with cantalevered joists. Even a great carpenter/builder has a hard time with bullet proofing the installation in several regards there. Moisture always seems to win over time. Can't even remember if it used to be 1 in 3 or 1 in 4 for cantalever.. who knows.
Interesting pic tho, thanks.
Tim
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 7/5/08, 11:27 AM
The upper decks... I'm not accustomed to see cantilevered joist's anymore. They still do that there? Been a few decks and apartment walkways collapse with cantilevered joists. Even a great carpenter/builder has a hard time with bullet proofing the installation in several regards there. Moisture always seems to win over time. Can't even remember if it used to be 1 in 3 or 1 in 4 for cantilever.. who knows.
Tim
Tim, Those are 2X10 joists with 6X6 post on 16" sonar tube with big foot plastic footings 4 feet below grade with 2 4ft pieces of rebar connecting the footings to the tube. It took 25 bags of cement for each tube/footing.
The cantilevered decks are 2X10X18 with 6 feet extending out for the balconies. This project is a 24X32 ranch that I'm adding a second floor to. I hired a structural engineer to develop the framing plan. The cost for the engineering was $4200.00, not cheap but worth it. I'll see if I have better pictures to post.
Old 7/5/08, 1:57 PM
Peter Doane's Avatar
Is that tree being used as one of the deck post? Looks really close from the picture.
I miss New Hampshah ! Spent many a summer on lake winnisquam
Peter Doane
NACHI ID# 05120681
Old 7/5/08, 4:58 PM
William J. Decker's Avatar
Please note the common features or these, and other such stories.
1) The deck detached from the house. Ledger board failure, not properly attached (should be threaded rods) or supported at the house side.
2) In each case, there was a party going on. Large number of people, maybe some jumping. Exceeds the regular load factors.
3) In our area, a while back, we had a rash of "deck collapses". In each case, the "deck" was actually a back porch for an apartment building or condo. In each case, the porch (which is different from a deck) was over sized. Porches are for egress only and not designed, nor intended, for parties.
4) Most of these accidents are caused by the owners not knowing these simple facts.
- Build it right.
- Have it designed by an SE, not just thrown together by some contractor.
- Don't over build it. Size it right.
- If it is a porch, it's a porch, not a deck.
- Best to have all decks supported by posts to the ground and not by ledger boards.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 7/5/08, 6:08 PM
This may help some:
http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf
Larry Kage, CMI
231 929 3525
Another deck Collapse rcooke Canadian Inspectors 11 3/30/08 9:03 AM
inspectorsites.com - sign up this weekend or wait until 3/15 inspectorsites.com Inspection Hardware, Software & Publications 11 3/9/08 7:38 PM
Floor Collapse jbushart Miscellaneous Discussion for Inspectors 0 8/4/07 8:09 AM
