Old 8/6/09, 5:50 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Tile Roof
Should you see this much wood members under the tiles???? Is the 2nd photo the correct way to repair a tile??
Thanks!!!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified Pennsylvania Home Inspector (and anywhere else in North America)
Old 8/6/09, 5:54 PM
Brian E. Kelly's Avatar
Default Re: Tile Roof
One No, two no.
Second picture looks like Silicone, it will not last.
Old 8/6/09, 6:26 PM
Thanks! This board is SO much help!!!!!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 8/6/09, 10:32 PM
1. That condition will allow moisture intrusion of the tile and possible eventual decay of the 2x hip cap support and insect infestation. At least (hopefully) there's underlayment under there.
2. Ugly, sloppy, failed repair.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 8/6/09, 11:34 PM
Dale Duffy's Avatar
Buck,
I inspected a new Concrete Tile Roof Covering install a few months ago for an elderly couple who didn't trust the contractor, he installed the ridge board just as you have pictured, bare, I told him it needed to be wrapped with the 30lb felt he was using as underlayment (two layers) on the decking but one layer over or around the pressure treated 2x4's and some untreated 2x4's he was trying to slip in at a couple ridges.
He basically told me to go to hell but the homeowners wouldn't pay him the last draw for the roof install.
We ended up having an inspector from the Arizona Registrar of Contractors come to the property to look at the way he installed the ridge boards, the state of Arizona made him tear off all the ridge Tiles and either wrap the 2x4's in felt or (equivalent-approved membrane for tile roof installs), or install the vinyl cap material they sometimes use rather than felt over the 2x4's before the cap tiles were installed and all the 2x4's had to be treated lumber.
Old 8/6/09, 11:52 PM
Dale, where did those requirements come from?
(303) 717-8940
Old 8/6/09, 11:54 PM
Dale Duffy's Avatar
The state of Arizona.
Old 8/6/09, 11:56 PM
Dale Duffy's Avatar
One of those Common Sense code requirements Kent...and the State of Arizona agreed with me.
Old 8/7/09, 12:49 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Good one Dale!!!!
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Garage Roof Tile gheller Exterior Inspections 4 6/18/08 9:23 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
