Old 12/18/09, 1:36 PM
David C. Macy's Avatar
Default Tile roofs
How do you approximate the age of tile roofs.
I see slate occasionally but do not do many tile roofs.
This one was on a century home but the stated age was 75 years old.
The age of the house would be one way but this one did not correspond to that theory.
ID:	33894   tile-roofs-151709-030-small-.jpg.jpg
Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America)
Old 12/18/09, 3:41 PM
Jeffrey R. Pope's Avatar
Default Re: Tile roofs
It's difficult to estimate an age for a tile roof. I would say the one you have pictured was a mid '70's install, just based on the tile design. I don't think that style is manufactured anymore, but I could be wrong.
More importantly, if the roof structure was not designed to carry the weight of concrete tile, you could have a major structural deficiency.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/18/09, 4:27 PM
What would be typical roof structure for a tile roof?
What would be considered a structural defect fo a tile roof.
Old 12/18/09, 4:43 PM
gbeaumont's Avatar
Hi Dave, I'd be looking for missing, broken or slipping tiles, bad mortar joints on the ridges and be paying very close attention to any visible flashings (they tend to fail before the tiles themselves). Also I'd be lookin for sings of leakage or discoloration of the tar paper underlayment if the roof has skip sheathing, do you have any more roof or attic shots?
I agree with Jeff BTW that is an older design my guess would be 60's
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 12/18/09, 5:31 PM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
This tile roof is bar tile. It’s no longer being made and it can be very hard to find these tiles. It’s common to see them clued back together. A few concerns about this tile….Is there felt under the tiles? Or was it sold sheathing with felt? Your photo of the valley tells me this roof is an older roof 20-50 years maybe? It was a common practice to install these roofs over skip sheathing with no felt. I have seen some of these roofs actually get water logged and have water go through them. The concert was so pores that water sweep through the tiles. DO NOT WALK ON THESE ROOFS….tiles are some of the weakest tiles ever made other than a natural clay tile. Even with 15 years of roofing and walking on thousands of roofs a year I will break these tiles. This roof is like any other tile roof if; its maintained correctly it can last for a life time. However if there’s no underlayment…oh boy we have another story…here…..
Old 12/18/09, 5:35 PM
i also dont like the look of the valley and tie in area....as a home inspector I would recommend a roof inspection on this bad boy....cya. have any other photos?
Old 12/18/09, 7:06 PM
wsiegel wsiegel is offline
How about public records? Asking the seller (if there is one). When all else fails, knock on a neighbors door. They might know.
Old 12/18/09, 7:08 PM
I learned that the hard way when I stepped through one. I will still walk these if they are installed over solid sheathing.
Dave - it's almost impossible to determine (visually) if the roof structure was designed to carry the load of concrete tile, but it's usually pretty obvious if the structure has been reinforced from original. When in doubt, defer it to an engineer, but look for stress fractures in the walls and ceilings that may indicate movement or unusual settling.
Always ask the owners (when you can) if they know the history of the roof - when it was replaced, what type of material it had previously - and look around the neighborhood. You may be able to get an indication based on what some of the neighboring homes have for roof covering, but maybe not on a home of that age.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/23/09, 12:23 AM
Look at the roof-covering materials on neighboring homes. If they're mostly tile, your's is proabably OK. Disclaim responsibility for confirmation of the ability of the framing to carry tile. You have no way of knowing.
Older tile will sometimes show efflorescence. High quality clay tile is almost like glass... extremely vitrified, and will not absorb moisture. Lower quality will absorb moisture, delaminate or flake, and exhibit microbial growth over the years, especially in freeze-prone climates. Some discoloration that you'd swear is mold is not (take my upcoming roofing video courses)
Concrete tile lasts pretty well. As Gerry mentioned, flashing, fasteners and improper installation are what to look out for.
Yep... look for bad flashing. Sidewalls should have continuous pan flashing with a raised edge to form a water channel.
... and good inderlayment. Tile usually has 30 lb underlayment or better specified by the manufacturer and code, but not always. If you see 15lb. recommend a specialist inspection.
Look for (and call out) exposed underlayment
Cracked, broken or missing tiles... call 'em out. The older the roof is, the more fragile. You don't have to walk tile roofs.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 1/27/10, 11:36 PM
Nick Gromicko's Avatar
Received this tonight:
On Wed, Jan 27, 2010 at 9:27 PM, Jon Carey <joncarey3@gmail.com> wrote:
> Was browsing your website and noticed the blog on how to walk on a red clay
> tile roof,.. all kinds of answers from being careful to renting a boom
> truck. Unfortuanetly none of thes work with much success. I have found in my
> 50 some years of building constructin that there is one way thats works
> pretty well and at worst case scenario will keep damage to a minumn.. You
> need two or three 10 foot 2x10s and about 9 to 12 sand bags. You start out b
> laying sand bag number one down then step om it and lay sand bag number two
> down about 3 feet in front of it then number three in the same manner. after
> that lay the first board down walk on it and start the process over
> again,,,if u run out of boards drop back get the first one andlay it in
> front of board three in a like manner.. I hope this was of help to the
> inspectors on your site... Feel free to post this information if you find it
> worth while.
> Jon Carey
Find a Home Inspector
Old 2/17/10, 12:41 AM
You don't. Your evaluation of the tile roof is not to give a remaining lifespan, which you should never do, but to evaluate it's condition. It's OK or it's not. Most important, if that tile roof is at or near the end of its useful life, you need to point that out in your report.
(303) 717-8940
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Does Asphalt Tile Roofs need Underlayment? Jan Lombard Exterior Inspections 12 4/3/07 9:38 AM
Spanish tile roofs bmiller2 Exterior Inspections 15 1/29/07 7:15 AM
