apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Fellow Inspectors,
Found this installation today. Comments welcome. Anatol |
Anatol,
What defect are you seeing? If it's the blackened areas...they are suppose to be exposed. That's the way they manufacture them. |
I don't see your concern, Anatol...5" exposure is typical locally.
What do you see? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
What would cause surface cracking like this?
The top of the tab cut are exposed on many of the shingles. The attachment size for picture is limited to 100kb so I had to reduce it. The adhesion strip should be fully covered by the next shingle. Exposure was over 5 inches.
Anatol |
Try cropping the photo in tighter to the tape and then reduce it as needed. I think that will show what you are looking at better. I think what your trying to point out is hat the installer cheated the rows by a 1/4" to 1/2" each row. (The dark shadowing would be smaller, but would still be showing.) Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
Your pictures do not show any adhesion strip. Roofing exposure of 5" to 5 1/4" is normal. This roofing is and looks like it was meant to be. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Ben,
Most likely a defective shingle. Anatol, They pass them all the time like that down here. The only time it may come into play is if someone tries to make a claim against the manufacturer, and then they will claim they are not installed to manufacturer specs. I would mention it, but nothing will ever be done about it. IF you are going to mention it, you should also include the installation instructions with your report. |
Cracking that you are seeing is typical of the known deficiencies of this product. Product has recently been the topic of Class Action Lawsuits filed in many States. http://www.nrlrc.net/news/details.aspx?id=57 http://www.sheller.com/Library/Certa...0Complaint.pdf http://www.sheller.com/Library/2006-...0Complaint.pdf Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 3/9/07 at 7:17 PM.. |
Thanks Joe.
here are some bigger pics at photobucket:
http://i112.photobucket.com/albums/n...p/Dsc00709.jpg http://i112.photobucket.com/albums/n...p/Dsc00708.jpg |
How about the crack just above the tape?
Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
The damaged shingles were mentioned in the report. As well as several leaks.
Anatol |
Attachment 9881 Last edited by dvalley; 10/7/07 at 4:40 PM.. |
| Asbestos | jlybolt | Exterior Inspections | 41 | 7/17/07 1:13 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| NACHI Chicago Education Meeting - Roofing | wdecker | Inspection Education & Training | 0 | 10/5/06 11:03 PM |
| Masonite Woodruf Roofing | reborn | Exterior Inspections | 3 | 3/10/06 10:45 AM |
