Old 4/24/07, 11:58 PM
jchamp jchamp is offline
Please Note: jchamp is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Tubular Skylight
Does anyone know if this tubular skylight needs additional insulation around the tube in the attic?
Old 4/25/07, 1:24 AM
Jason1's Avatar
Jason1 Jason1 is offline
Please Note: Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Tubular Skylight
Nah....
Old 4/25/07, 1:36 AM
Nope. Kind of like a big double-pane window.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 4/25/07, 8:50 AM
phinsperger's Avatar
And just how energy efficient is that big double-pane window? I would definately insulate around it in the attic as you suggested.
Old 4/25/07, 9:12 AM
Unmoderated Guest
The skylight is closed at both ends. No conditioned air can get into the tube.
Old 4/25/07, 9:27 AM
There is still heat loss into the chamber where its sealed or not. Why not insulate the outside of the tube that runs through the attic and reduce the heat loss from that large surface area. There will still be some loss through the dome but the less the better.
Old 4/25/07, 10:13 AM
mthomas2 mthomas2 is offline
FWIW, the Solatube installation instructions make no mention of insulation:
http://www.solatube.com/downloads/20...60DS_290DS.pdf
Old 4/25/07, 1:16 PM
You wouldn't lose heat through convection, since there are no air currents in a sealed tube. You wouldn't lose heat through radiation, because there's so little thermal mass. The only way to lose heat would be through conduction, and the only surface exposed to the warm interior is the clear face. The sheetmetal sidewalls of the tube are thin enough that it's hard to imagine much heat getting transfeerred from the clear face to the sidewalls and being conducted to the cold attic or exterior.
The only reason I can think of not to insulate is the possibility of condensation forming and becoming trapped.
(303) 717-8940
Old 4/25/07, 1:36 PM
I'm afraid I disagree with on this one. With the size of the tube, convection air currents most certianly would occur, even in a sealed unit.
With double-glazed windows, the air space between the panes of glass has a big effect on energy performance. A very thin air space does not insulate as well as a thicker air space because of the conductivity through that small space.
During the 1970's a lot of window manufacturers increased the thickness of the air space in double-glazed windows from 1/4" to 1/2" or more. If the air space is too wide, however, convection loops between the layers of glazing occur.
The same principle applies to the tubular skylight.
It may not be required to insulate but the cost of insulation will easily be recovered by the savings in heat loss.
The only condensation (not roof leaks) problems I have every seen have been with regular skylights where the moisture entered in from the open bottom skylight well. This should not be a problem in tubular skylights. Moisture from the attic side is unlikely if the attic is properly vented and sealed from the conditioned space.
Old 4/25/07, 1:59 PM
I just got off the phone with Solatube. They don't recommend insulating the tube for condensation reasons.
(303) 717-8940
Old 4/25/07, 4:27 PM
Can you explain to me where and how this condensation occurs?
Old 4/25/07, 5:00 PM
Paul, I just googled them and called customer service for contractors. The guy said something about energy star and heat loss being taken into account during design. The cell signal wasn't that good and I didn't really ask for details. I'm sure there's some heat loss but I think it's pretty minimal.
(303) 717-8940
Old 4/25/07, 8:29 PM
Grab a coffe guys and see if this helps.
Why Tubular Skylights?
Why Choose This Brand?
Incandescent Light Kit
Download the installation guide
The System
• High-impact acrylic dome
• Unique condensation release system
• Bug and dust proof sealing system
• Seamless air-craft grade aluminum flashing
• Water tight
• Fits all roof types
• Alanod Miro Silver 98% reflective light pipe
• Aluminum trim ring and stress collar
• Quick and easy 2 hour installation
• No structural changes or painting required
The Protection• UV protection built-in no fading
• Virtually no heat gain or loss
• Condensation system keeps moisture outside
• Only dome on the market with
factory mounted stress equalizing collar
Warranty Registration - Click Here
• 25 Year Warranty
ICBO Tested and Approved
Florida Building Code Approved
• Hurricane Tested and Approved
Marcel
Old 4/25/07, 9:27 PM
Joseph Hagarty,  CMI's Avatar
Manufacturer's recommendations for the particular product prevail.
I would not recommend deviating from the installation guidelines and offering alternative installation (insulation) methodology.
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 4/27/07, 5:32 PM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
The sola-tube installation is NOT air tight. Only water tight at the roof line, "Hopefully". We all know what happens to dual glazed windows when they loose they're air tight seal, hello condensation.....
New Skylight jhagarty Exterior Inspections 8 6/10/07 9:32 PM
