Right
Troy Pappas Virginia Beach Home Inspector Professional home inspector serving Virginia Beach, Norfolk, Suffolk, Portsmouth, and Chesapeake 757-418-0944 |
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
To allow for proper drainage.
Thats awsome!
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Make sure it is not a "drop plate" beam first.
Useless if it is actually split .
caulk that vertical freeze board
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
That mullion should be able to carry that load.
Hearth and Homes Inspections 440-954-0465 www.euclid-home-inspector.com www.hearthandhomesinspections.com www.lakecountyohiohomeinspectors.com Control your own destiny, or someone else will. |
The shelf is separated.
Even if there was a plate welded to the back it still can flex horizontally. 1.) Cracking in masonry butt joint above the separated lintel. 2.) Missing masonry between the 7 and 8th clay brick solider header. Weeping system in headers are dependent on the layout. I would call it out. Unconventional brick self or lintel. Recommend licensed mason install a lintel. Minimum 4" inch bearing on brick. Poor pointing. Look at the brick ( side face lead edge. ) The vertical line at the opening.. It is not plumb. 1/16' % degree in variation in plumb or vertical line is allow in masonry building. Poor brick masonry practices. Open voids; Vertically driven weather will degrade components at an accelerated rate. The wider the opening, the faster the degrading process. I would charge $1000 dollars to repair that properly.
montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
gmartin2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
slipshod workmanship?
| Any rough framers have a 2009 IRC? I have a question. | gromicko | General Inspection Discussion | 27 | 6/16/11 9:20 PM |
| Efflorescence patterns to diagnose water intrusion | wdecker | Exterior Inspections | 26 | 1/9/10 7:58 PM |
| Missing lintels? | tpetersen | Structural Inspections | 8 | 5/17/09 8:40 AM |
| Steel lintels? | sberlett | General Inspection Discussion | 13 | 6/13/07 8:17 PM |
