Old 6/3/08, 11:41 PM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is offline
Please Note: Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default What type of roofing material do you think this is?
What type of roofing material is this?
Do you guys have any good information with pictures about the different types of flat roofs and problems associated with them?
type-roofing-material-do-you-think-dsc08610.jpg   type-roofing-material-do-you-think-dsc08607.jpg
Old 6/4/08, 12:34 AM
gbeaumont's Avatar
Default Re: What type of roofing material do you think this is?
Hi Kevin,
do you have any other or higher resolution pictures of that roof, to me it could be either EPDM or modified bitumen with a UV relective paint from what I can see, problem is it also looks wavy enough to be SPF
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 6/4/08, 12:37 AM
Justin Watts Justin Watts is offline
It looks like a membrane roof to me... synthetic rubber used a lot on commercial rooftops. And yes regardless of material all flat roofs leak! Make sure you tell your client this....
Old 6/4/08, 2:22 AM
Dale Duffy's Avatar
Originally Posted by gbeaumont
Hi Kevin,
Regards
Gerry
Ditto...looks like EPDM with SPF applied, and the reflective coating is shot.
Old 6/4/08, 9:52 AM
Kevin Luce's Avatar
These are all the pictures I took of the roof.
type-roofing-material-do-you-think-dsc08606.jpg   type-roofing-material-do-you-think-dsc08607.jpg   type-roofing-material-do-you-think-dsc08608.jpg   type-roofing-material-do-you-think-dsc08611.jpg   type-roofing-material-do-you-think-dsc08613.jpg
Old 6/4/08, 9:58 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
What everyone else said.
Check flashing along the parapet wall,open seams ,and roof penetrations.
Old 6/4/08, 10:30 AM
gbeaumont's Avatar
Hi Kevin,
here's my "best wild*****" guess. I think you are looking at a modified bitumen ply roof with an aluminium oxide solar reflective paint (the roof being wet doesn't help).
The reflective coating is shot as Dale said, plus the opening seams and the lumps and bumps are indicative of moisture migrating between the plys.
As Bob stated the cap flashings on the parapet walls also look highly suspect.
Given the doubt about the exact material and its obvious condition I would recommend futher evaluation by a roofing specialist, but I'm pretty sure that is going to need a new roof.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 6/4/08, 11:41 AM
relliott's Avatar
Got another commercial inspection Gerry.
12 units and I will be using your great message in a photo tip once again.
Old 6/5/08, 4:33 PM
William J. Decker's Avatar
With those clay coping tiles, check and see if they are sealed properly. If they only used black roofing dope, they will leak within the year.
See it all the time, around here.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 6/5/08, 5:13 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Care to share the tip?
Old 6/5/08, 9:14 PM
mreusch mreusch is offline
Send a message via Yahoo to mreusch
Hi Kevin,
Regards
Gerry
Absolutely right on about the PAINT. I was using that stuff 20 years ago on walk out porches to reduce the heat. The only good thing about it was when it began leaking you could find it really easy because it showed a black line where the seperation was instead of the silver coating.
Commercial Electrical Inspections jtedesco1 Commercial Inspections 29 1/12/08 6:03 AM
Asbestos jlybolt Exterior Inspections 38 7/17/07 2:13 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 1:21 AM
Roofing material being grandfathered dnasser Exterior Inspections 4 4/2/07 12:01 PM
Has anyone seen this type of vent material? scosta Inspecting HVAC Systems 12 3/9/07 3:30 PM
