Old 7/9/08, 2:52 PM
Ronald G. Chorey II's Avatar
Ronald G. Chorey II Ronald G. Chorey II is offline
Default What type of siding
I am wondering what type of siding this is or what it is called. It is not metal or vinyl. It appears to be some sort of wood/paper stuff. Yes and I know it is moisture damaged, just want to know what to call it. Do not see it here much Anyone have a clue. Thanks
Old 7/9/08, 2:59 PM
mnahrgang's Avatar
Default Re: What type of siding
looks like Masonite to me...
correction... Masonite is a brand. Fiberboard is more accurate.
Mark Nahrgang
www.HeyMark.info
Old 7/9/08, 3:00 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Possibly some brand of Fiberboard.
http://www.do-it-over.com/siding-glossary.htm
Old 7/9/08, 3:03 PM
Thanks
Old 7/9/08, 3:04 PM
Christopher Currins's Avatar
Hardboard siding.
Hardboard siding is made from a mixture of wood fibers, wax and resin. These materials are heat-treated and pressed together to form panels that resemble wood, giving them a uniform appearance of wood without the defects such as knots or raised grain. The composite wood product can be manufactured to resemble traditional, crafted siding elements for a lower cost than real wood. Today’s hardboard siding is engineered with improved termite and moisture resistance.
Siding Information
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 7/9/08, 3:09 PM
Michael Larson's Avatar
Looks like "pressed hardboard" siding. A lot of it was used in the '70s and '80s and into the '90s
Works fine until and when the moisture gets to it.
A lot of it is junk by now in my area.
FAQ
Manufacturers
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 7/9/08, 5:32 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Same here Mike. It doesn't stop the so called "siding experts" from putting vinyl right over top of the moist fiber or hardboard.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 7/9/08, 5:40 PM
Robert J. Wind Robert J. Wind is offline
LP siding
Old 7/14/08, 6:26 PM
dhelm's Avatar
dhelm dhelm is offline
Definitely is not LP siding. Definitely is hardboard siding.
Helm Home Inspection
David Helm, Owner/Inspector
http//www.helmhomeinspections.com
Old 7/14/08, 6:38 PM
Michael R. Boyett's Avatar
Best place I've found to identify specific siding is: http://www.sidingsolutions.com/pages/sidingid.htm
(Note: some of the links on that website are no longer valid but most are and the photos help a lot as well)
Old 7/14/08, 10:14 PM
Found this that may help also.
How To Identify Damaged Hardboard Siding
Homeowners Quiz
Requires Adobe Acrobat Reader
A quick quiz for homeowners
Most homeowners don’t think they have a problem, because they haven’t taken the time – or don’t know how – to properly examine their hardboard siding.
Qualifying damage may not be visible to the untrained eye, and many homeowners are unfamiliar with the court-approved damage protocols and inspection procedures. Without a professional evaluation, you could miss your opportunity to receive a fair settlement.
ClaimSource One has identified and evaluated more than 75,000 properties over the last five years and found that most had some type of qualifying damage. We can help you start the claim process today with a brief inspection that takes less than 15-20 minutes.
Some of these photos are shown in very advanced stages of deterioration. Your hardboard siding does not have to look as bad as the photo examples in order to qualify for compensation.
Take the time to review this checklist. If you answer “yes” to one or more of these questions – or are unsure about any of them, call ClaimSource One and let one of our trained inspectors evaluate your property.
Start by finding unexposed, undamaged pieces of siding. For example, choose a board that is under an overhang (most likely, undamaged). Notice the good condition. Compare this against the weather-exposed areas around the house.
Is the drip edge, or bottom edge of the siding, swelling or cracking?Is there swelling and peeling at the joints where boards are joined together?
Does the siding swell around the nail heads to the extent that the nails look sunk in?
Are any pieces of the siding deteriorating? Pay close attention to boards that are closest to the ground.
Do the boards buckle and appear to be warped?
Is there fungal growth on the drip edge of the siding?
Is your paint peeling and flaking and is it difficult to get paint to stick to your siding?
Hope this helps a little.
Marcel
Reckless comments incriminate sellers in home siding suit gromicko Exterior Inspections 2 2/26/08 11:44 PM
Commercial Electrical Inspections jtedesco1 Commercial Inspections 29 1/12/08 6:03 AM
What Type Of Siding Is This? gmoore2 Exterior Inspections 13 3/30/07 2:18 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 4:38 AM
