Old 6/9/07, 11:49 PM
sfalvey sfalvey is offline
Default Under framed roof
How do you guys report a 40+ year old roof that is under framed by todays standards, but may have been fine when it was installed?
This roof is built with rough sawn 2x4's some of which are sistered and do not run the entire length of the slope. I noticed at least one collar tie that has broken and several areas where the old dimensional decking has cracked, I am guessing from snow judging from the sags in the roof. Shingles need to be replaced, not leaking yet, but are cracking horizontally, have some deterioration and some moss growth.
Thanks again for your wise words.
under-framed-roof-img_01821.jpg   under-framed-roof-img_01881.jpg   under-framed-roof-img_0192.jpg
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 6/10/07, 9:14 AM
David P. Valley's Avatar
Default Re: Under framed roof
Scott,
If there's no obvious defects, I don't recommend upgrading or reinforcing unless deflections or sagging are present. I've seen many rafters spaced at 36 on center that are in perfect condition with no sagging whatsoever.
I simply note the size and spacing of all roofing and flooring members in all my reports.
Old 6/10/07, 10:02 AM
mnahrgang's Avatar
Scott,
I'd say what you said. Include the pics you took. And move on.
Observe, report, go on...
Mark
Old 6/10/07, 12:50 PM
Unmoderated Guest
It looks like someone has installed some colorful supports anyway, and it also looks like the effective rafter span isn't all that great.
Old 6/10/07, 7:35 PM
afrost afrost is offline
Please Note: afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
i'm not sure you want to put yourself on the line and say that it is "under framed". note what you see and, if you think it needs additional work or an engineer's eye, then suggest it.
the shingles may be near the end of their usefull life, but it may not have anything to do with the framing.
Old 6/10/07, 8:30 PM
Ted Allen Ted Allen is offline
Originally Posted by dvalley
Scott,
Indeed..
Old 6/10/07, 8:31 PM
Scott,
Hi Dave,
Thanks for the input. The roof actaully has fairly significant sagging, I would venture to say about 3"+ from top to bottom.
Scott Falvey
Newbury, NH
NACHI#05051292
Old 6/11/07, 6:31 AM
Originally Posted by sfalvey
Hi Dave,
Then write it up as such....but stay away from telling your clients how to reinforce such an area where you have little expertise. Leave that to the licensed Experts.
Old 6/11/07, 7:35 AM
rwand1 rwand1 is offline
Roof plane is sagged. Framing does not meet current framing specifications due to age of structure. Additional framing maybe required. Seek advice from framing contractor.
Old 6/11/07, 4:11 PM
I like it, thanks guys.
Scott Falvey
Newbury, NH
NACHI#05051292
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 10:50 AM
Cracked shingles pwigle Exterior Inspections 54 4/23/09 11:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 12:21 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
