A seasonal stream has been covered using 12 inch culvert, spanning about 100 yards. The stream is currently flooding the property. Any drainage experts.
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm guessing that if it is a seasonal stream...the house is possibly built in a flood plain? That should be covered under state regs....and should be checked by the zoning authority of your county...correct?
I would recommend that flood plain research be done? |
jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
with the amount of rain we've had here in W. Wa. this season, I think there is a lot of abnormal flooding happening. I see standing water in many places that during a normal winter we wouldn't have. A lot more basements having problems, there's just no where for the water to go! Since Oct. we are 24" above normal precip. This mo. has had over 9" above a normal Jan.
Joseph A. Ferry, Esquire Two Penn Center Plaza Suite 200 Philadelphia, PA 19102 215-854-6444 tel. 215-243-8202 fax |
What do you want to know Brandon?
-Kent |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 12:39 PM |
| Two ground wires | jlybolt | Electrical Inspections | 8 | 8/10/06 3:06 PM |
| Harmonized Ground Fault Circuit Interrupters | jtedesco1 | Electrical Inspections | 5 | 3/21/06 9:48 AM |
