Old 9/8/11, 11:15 AM
Gregory A. Liebig's Avatar
Gregory A. Liebig Gregory A. Liebig is offline
Default Unsupported Sectional Chimney Height?
Ignore the brick chimney on the right. It's already a reported defect with an oil fired forced air furnace sharing the same flue as a supplemental wood fired forced air furnace. Creosote is type of liner, right?
I'm concerned at what height is a sectional chimney needs support? Guy wires or otherwise. This one measured from the high side is at 93". It's a DLR (doesn't look right) to me. Any suggestions? Thanks!
unsupported-sectional-chimney-height-sam_5067.jpg   unsupported-sectional-chimney-height-sam_5059.jpg
Greg Liebig, Owner
Sheboygan Wisconsin Home Inspector
4-Square Home Inspections, LLC
Where Knowledge will put your Mind at Ease ©
Sheboygan, WI 53081
(920) 451-4646
www.sheboyganhomeinspector.com
www.4squarehi.com
Like Us on Facebook
Follow Us on Linked-In
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/8/11, 12:26 PM
Marcel Gratton's Avatar
Default Re: Unsupported Sectional Chimney Height?
Below is what I say in my report along with the attached pic.
· Repair:The metal chimney should be braced in order to ensure it remains stable in high winds. Lack of bracing for taller chimneys can lead to collapse causing property damage and personal injury. Metal chimneys that extend five-feet or more above the roofline usually require bracing. A chimney specialist should be consulted to further evaluate this condition and provide repair/improvement recommendations.
On The Level Inspection
Gatineau, Québec
Old 9/8/11, 1:04 PM
David C. Macy's Avatar
Chimneys are to close to each other. Does not follow the 10/2 rule
Old 9/8/11, 1:11 PM
Good points on both comments. Thanks so much. This is a great reason not to print reports on-site (IMO). I did include Marcel's picture in the report.
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Like Us on Facebook
Old 9/8/11, 2:01 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
Correct on both statements and part of the schooling for WETT Site Basic in Canada.
Even if they are both done right there must be at least 18" clearance between the two chimneys according to Canada CSA standard.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/8/11, 2:09 PM
Jeffrey R. Jonas's Avatar
Greg,
I forget at the moment, as I don't see it very often, but isn't there something about two chimneys being at the same height when they are within a certain distance of each other? Aren't they supposed to be offset?
Old 9/8/11, 2:18 PM
KEVIN WOOD's Avatar
You must have been typing at the same time Jeffrey! LOL
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/8/11, 2:20 PM
Musta been. I just noticed your post time and edit time. Brilliant minds...
Old 9/9/11, 7:54 AM
I was going to mention the separation but it appears to be within requirements from the pic but only Greg knows...
Gatineau, Québec
Coming soon. Free, online, fireplace and chimney inspection course. gromicko General Inspection Discussion 15 12/14/09 4:19 PM
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 6:11 PM
Difficult Chimneys thance Inspecting HVAC Systems 2 1/29/08 8:16 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Chimney Height for combustable gas dmacy Exterior Inspections 7 1/21/06 8:58 PM
