Old 11/15/10, 4:34 PM
John Evans John Evans is offline
Default Unusual tar material at sheathing seams
Typical shingled gable roof approximately 10 years old. Found what looks like tar leaking through some sheathing seams. The roof surface appears normal. Any input would be appreciated.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/30/10, 11:30 PM
Default Re: Unusual tar material at sheathing seams
I doubt it came from the shingles, John. My guess is that the installer (probably a homeowner) wanted to seal the joints between roof sheathing panels against leaks, so he applied mastic to the joints as he went. Not a good idea, since it will limit the ability of the panels to expand with changes in moisture content. There's the potential for bowing (bulging) of the sheathing as panels expand.
The potential problems represented by that condition are related to the level of seasonal changes in humidity in the area in which the home is built. Maryland is pretty different from Colorado in that respect so you're a better judge than me.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 12/1/10, 7:04 AM
jmoya jmoya is offline
I'm with Kenton. Based on the pictures 2 and 3, although a little difficult to tell, it looks like the sheathing was going bad, probably from the inside, attic. They may have applied tar (maybe hot tar) to the entire roof to seal it.
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 12:52 PM
Repairing flashing and sheathing Dawn Gentry General Inspection Discussion 4 10/27/08 8:49 PM
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
Use of ThermoPly without underlying structural sheathing? koconnor Structural Inspections 12 10/16/07 7:52 PM
Asbestos jlybolt Exterior Inspections 41 7/17/07 1:13 AM
