| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
How would you identify the valley.
1.Asphalt 2.Not visible When the roofer shingles over the valley is there a metal valley underneath? The roof is the 2nd layer. Are they just using the old valley below. Would you report the valley as not visible or identify as asphalt. I thought the area between roofs was a potential leaker. Also if there is no drip edge at the gutter do you report it as missing? You can not see in the photo. I have not seen the screw attachment for the gutters. Looks like a couple screws are backing out. Thanks |
Looks like a "western cut" valley as a "room addition/roofer" explained to me once. The shingles lap underneath on one side of the valley. My old house leaked there when it rained real hard after they added on a sunroom. The underlap was not enough. Needs to be at least 8 inches.
Drip edges are not done around here but might be required up north. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 |
By second layer, I assume (I know I should never use that word) that this is what we call a roof over. If so , the you would not see the valley metal unless you can see it under the first layer at the edge of the roof. That is a woven valley, which is quite common.
Are you sure that is a second layer of shingles. Usually dont see that with a ridge vent. At least here in Fl, ridge vents are a fairly new phenonemon. Also, usually with a roof over there should be a drip egde present. Maybe you guys in Ohio do it differently than us Southern folk. Bill Siegel Florida Home Inspection Team Inc. |
Lately, the builder's roofers have not been using drip edges -- and it shows.
All the quality roofing companies here require the drip edge --and it shows. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
I will have to post a picture of the woven valleys on my house.
Those pictures are not woven valleys as I know them. A woven valley has no crack down the center. those pictured are also called mitered valleys Here is a woven valley http://www.stargroup.com/Residential...html~mainFrame B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 Last edited by bking; 3/12/07 at 10:27 PM.. |
This is a single cut mitered valley, one side should extend 12 to 16 inches past the valley transition. the opposing side is then cut along the transition line, hence, the single cut mitered valley. Valley flashing on this type of roof can be seen at the leading edge where it falls into the gutter. Valley flashing is to reinforce the transition ( or bridge the gap ) where roofing does not generally conform to the substsate. It keeps you from tearing through the roofing if you step on it or a tree branch falls there, by forming a flexable yet reasonably solid substrate.
jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with Jae. Lack of drip edge shows Regardless of the climate, it helps preserve wood fascia and trim, cuts down on maintenance costs, and saves the homeowner money in the long run. They don't install it that often around here, either, but that doesn't mean they shouldn't. I always call it out and explain my reasons for doing so. What do roofers and builders think, they make that stuff just to sit on the shelves at Home Depot?
Jimmy B. |
This is a closed cut valley (picture is from the wrong angle and not close enough to be 100% sure) or maybe a california.
The concern here is none, this is an acceptable means of installation and it is not recommended that metal be installed prior to the shingles, however it is recommended that ice & water shield or a roll product is installed on the deck prior to the installation of the valley detail. The details for this installation can be see at www.certainteed.com if you care to see it. The type of shingle you will look under will be called Landmark. I will point out that one post noted that the shingles must underlap at least 8 inches, the spec is that they carry over not less than 12 inches and nailing in the valley must be kept out about the same. Problems to look for with any valley is leaking of course, look also for poor workmanship which should have you look closer as you may find that the parts that are not readily visivle will be installed improperly too. The shingle in the picture is a Certainteed Landmark in the color Colonial Slate, the product could be a 25 or 40 year product and is likely to be 5 years old or older. The black shadow highlights on the cap shingles and the field shingles are distinctive to this product Note, with the type of shingle pictured, architectural/dimensional, call out when the valley is installed with a full weave! problems can occur when installed using the full weave and the factory spec's recommend against this method |
Hi to all,
This may help you to see it Dave Regards Gerry (Image courtesy Michael Rowan Inspection Depot) Virtue is more to be feared than vice, because its excesses are not subject to the regulation of conscience. Adam Smith (1723-1790) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106
ccurrins is a non-member guest and is in no way affiliated with InterNACHI or its members.
Closed-Cut Valley
"Click to Enlarge" Attachment 10032 Weaved Valley "Click to Enlarge" Attachment 10033 Last edited by dvalley; 10/7/07 at 5:40 PM.. |
Ohhhh...And don't forget the most important Valley. The renown David Valley
A mile from Town is a Parish by the name of Saint David, in the Valley. Saint David is still alive. I be darn. Marcel Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Valley flashing | rray | Exterior | 12 | 7/1/07 2:31 PM |
| NY NACHI Hudson Valley Chapter Meeting | pmaietta | Misc. Discussion | 0 | 4/23/06 9:48 PM |
| NY NACHI Hudson Valley Chapter Meeting | pmaietta | General Inspection Discussion | 1 | 3/24/06 7:51 PM |
| NY NACHI Hudson Valley Chapter Meeting | pmaietta | General Inspection Discussion | 3 | 3/3/06 11:43 AM |
| NY NACHI Hudson Valley Chapter Meeting | pmaietta | Misc. Discussion | 0 | 2/27/06 2:42 PM |
