Old 4/11/10, 12:24 PM
David C. Macy's Avatar
Default vent penetrations
On a recent inspection when evaluating the exterior vent penetrations I came across an unusual configuration. I stated to my client I would need to see the inside to determine. Turns out whatever vented through the opening was sealed with the unusual cover. They improperly cut portions of the floor joists.
It must of been the same person who used for a furnace intake vent a glass block window, dryer exterior vent cover, duct tape, no glue at fittings, supported with angle iron at the return duct system. For your enjoyment I added some photos.
Also the dryer exterior vent was broken, (Not a big deal) and one of the bath vent covers was improperly installed and the bath vents terminated in the attic.
Seems like every vent termination on the outside was messed up on the outside and inside. Makes me think it was the same person.
ID:	36398   vent-penetrations-158810-081-small-.jpg.jpg
ID:	36399   vent-penetrations-158810-072-small-.jpg.jpg
ID:	36400   vent-penetrations-158810-071-small-.jpg.jpg
ID:	36401   vent-penetrations-158810-014-small-.jpg.jpg
Old 4/11/10, 12:51 PM
Banned
Default Re: vent penetrations
Originally Posted by dmacy View Post
This guy must move around quite a bit! Got to be the same guy that did the plumbing on a small new retirement home I inspected a couple years ago. The joists were butchered in one area. Should have known he was only a part time plumber..................his full time job was as a butcher!!
He must just be allowed to chop up the stewing beef.
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Plumbing vent next to exhaust vent mpettitt Plumbing Inspections 5 10/12/07 5:38 PM
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 9:17 AM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
