Is anyone else running into this problem on a regular basis. I guess the codes have changed down here. This is now what we are using for a gas vent stack. I have seen this four times this week on different houses with new roofs installed.
I don't like it. Looks like a wind from the left would create a very strong downdraft.
Jim King |
James,
My fault. What I meant to say is that this is what they are using (agianst code). The picture below shows what they should be using. |
William,
Do you know if it is the same roofing or HVAC guy on all the homes? Good catch. 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Bruce,
No. No idea. Unfortunately it is up to the roofing company to supply the information to the building dept. when then file for a permit. If they do not tell the dept that there is an appliance or water heater that uses a stack, the city will never know (they never enter the home or look in the attic). This happens a lot down here. |
Never seen picture #1 used that way up here. Show your clients manufacturers installation specs. not code. Then refer to code. if needed. When they see that manufacturer does not O.K. them to be used that way you don't have to mention the dreadfull "C" word.
William
We use to design and install that type of roofvent for Bath Fan(s) or RangeHood discharge piping. I can't believe any reputable HVAC or Plumbing Contractor would use that type of discharge for any type of gas-fired appliance flue venting. I also can't believe any Code or Independent Home Inspector could miss this vent problem. Could the Roofing Contractor have made this modification on his own, removing older rusted piping? Either way, I'd check or recheck it for sure, make sure I know what I'm reporting, then write it up. |
This seems to be typical practice down here these days. I forget the exact height the vent is supposed to be, but I believe it is supposed to terminate two feet above the roof line. This is other vent stack was on the home behind this house. This one is correct.
William
Just checking back, I noticed your 2nd Pic of a typical and acceptable vertical "B-Vent" type flue vent. It appears older, some rust, but otherwise fine. The other design can't be acceptable in your area... must have been a bad choice by an unknowing or stupid Roofing Contr. |
| Plumbing vent next to exhaust vent | mpettitt | Plumbing Inspections | 5 | 10/12/07 5:38 PM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 9:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
