![]() [ATTACH]14756[/ATTACH Is it just me or is there someone out there think there is something wrong with the way the siding is attached around the window. The home is about one years old. If someone has any information on a link that I could use for general information on the correct way to install vinyl sinding , I would appreciate it. Bruce MacInnes Bruce MacInnes
Noblesville,IN 317-513-1727 www.macinnesinspection.com |
Oh yea, that's wrong!
First it appears to have improper flashing around the perimeter of the window casing. With the vinyl install it is missing the J channel. Both of these will allow water, air, and insect penetration.
Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January Last edited by ccurrins; 9/26/07 at 4:33 PM.. |
Very wrong! Also very important is whether or not the window was properly flashed prior to the vinyl siding installation. I find most are not. Without the proper flashing even with the J channel the water will end up being diverted into the wall around the window and door openings. Just from looking at this I would bet the installer did not know what they were doing or just plain lazy (and cheap). I hate vinyl siding because it may look good from the exterior, meanwhile all kinds of things could be going on behind it. CYB well on this and any future ones like it.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Michel, Thanks for the information.
Bruce Bruce MacInnes
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
The only thing wrong with it is the siding may be cut a bit too short. The siding should be cut about 1/4" shy to allow for expansion and contraction. If it's cut too wide or if the siding has shifted from side to side the gap your photo shows will occur.
The window in the picture is of the type that has it's own built in receiving channel and therefore requires no "J" . What you see in the pocket of the receiving channel does ,in fact, appear to be flashing. If the flashing had been stuck on just 1/4" away from the angle of the pocket the installation would have looked much better. |
Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
That window is called a new construction window in my neck of the woods. The J channel is built into the window frame and has a nailing flanged that protrudes away from the frame and is under the siding. To flash this window we use a product called Vicor which is basically ice and water shield and it come in 6", 8", or 12" rolls. Once the window is installed you apply the Vicor over the nailing flange starting at the bottom of the window, then up the sides and the top last.
One important thing to remember is, in order to complete the building envelope the top of the window nailing flange must be under the building paper and then the Vicor can be installed. The picture posted here you can see a bit of the Vicor against the window frame, it is black just like ice and water shield. I see nothing wrong with this installation other than that. |
That being said, it is cheaper, faster, thus more cost effective when building and the window MFG. can mass produce these windows in common sizes. Next time your driving around, take a look at new construction houses in your area, you will no doubt notice that the second floor windows and the first floor window are the same size and appear to be large, the reason for this is they are all new construction egress windows, 6/6 grids, built in J channel, vinyl sided houses. This kind of building practice has been around for years and it allows a builder to budget X amount of windows at X amount for a price and build X amount of houses thus you have cost control or standardization. Hope this helps. |
Here's an interesting link.
http://www.taunton.com/finehomebuild.../021149082.pdf Michael Barnett C.H.I. #NACHI07081803, HIF#9725A Barnett's Certified Home Inspections BL#10009708 (661) 816-4123 www.barnetts-inspections.com mbarnett@ca.nachi.org www.nachi.org |
I suppose you could but most builders will not do the extra, also, many homes today will have vinyl shutters installed and then you will never even notice.
| Do you unzip vinyl siding? | apfaff | Exterior Inspections | 13 | 7/23/08 9:49 AM |
| ALCOA vinyl siding one side warping, why? | Lynn Kelly | General Inspection Discussion | 4 | 5/23/07 5:32 PM |
| Vinyl siding window trim | jclark1 | Exterior Inspections | 14 | 6/6/06 10:46 PM |
| Vinyl Siding Install | psmothers | Exterior Inspections | 3 | 4/21/06 3:44 PM |
| House fires spreading due to proximity and vinyl siding | bking | Exterior Inspections | 5 | 4/10/06 11:04 PM |
