Old 6/24/11, 11:23 AM
Barb Johnson Barb Johnson is offline
Please Note: Barb Johnson is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Vinyl siding installation adverse weather condition
I am paying for a new siding job. Contractor started 3 sides of house, never completing a side to the top, prior to a heavy rain storm. Contractors left when the rain came, but left the material exposed. Boxes of Aluminum clad for windows left outside, 1x3 for cladding, & vinyl in boxes, Dow TUFF-R insulation left outside.
I am concerned for 2 things.
1. Wind blown rain, seeping down the vinyl siding & the insulation board. Will this cause a moisture problem & affect Certaintee warranty.
2. I do not feel wet materials should be installed.
Any help appreciated.
Thanks
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/25/11, 11:56 PM
Default Re: Vinyl siding installation adverse weather condition
Thanks
Many building materials, especially exterior veneers, can cope with a certain amount of adverse weather before they are finished, what is more of a concern is simply that the moisture does not get trapped behind the building envelope.
What is the type and condition of material that the vinyl siding is being applied?
Jeff
Old 6/26/11, 12:17 AM
Jeffrey R. Jonas's Avatar
Jeff
Agree with Jeff above.
Typically the new vinyl is applied over the existing siding after a moisture barrier and additional insulation is applied (existing home). There is usually little concern with the vinyl not being complete during a rainstorm.
On a new home, or if the original siding was removed down to the sheathing, it is a concern for moisture intrusion, if the moisture barrier was not completed brior to the rainstorm. If it was not, the "wet" walls should be allowed to completely dry out prior to closing it up.
Just for your information...
Vinyl siding is not waterproof. And is not intended to be. If you look at the bottom edge of the siding you will see 'slits' or 'weep holes' every few feet. This is to help any moisture that gets behind it, to drain and dry out.
Hope this helped.
Jeff
Old 6/30/11, 5:52 AM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
"Vinyl siding is not waterproof. And is not intended to be. If you look at the bottom edge of the siding you will see 'slits' or 'weep holes' every few feet. This is to help any moisture that gets behind it, to drain and dry out."
This is an oft repeated fallacy repeated over and over by sloppy installers until it's starting to become 'fact'. It's the siding industry's way of saying they're not responsible for building defects into your home because of a lack of proper installation training.
Here's a helpful link. http://www.albertsroofing.com/Window%20Flashing.htm
Old 6/30/11, 11:43 AM
Originally Posted by ryoung7 View Post
Frank that is one confusing statement.
"Vinyl siding is not waterproof."
The thread is talking about tin or aluminum with insulation backing.
As for you water proof statement. make sense sir.
It is meant to keep the exterior envelope water tight yet have the ability to shed moisture and regulate humidity.
WOW. WATER PROOF?
Robert... re-read post #1...
Thanks
Old 6/30/11, 11:45 AM
Robert, the quote didn't format properly in Frank's post... the "waterproof" comment is mine. See above.
Old 6/30/11, 11:57 AM
Frank,
Nice to see you again.
I agree most issues with any facet of home construction/remodel/repair can be traced back to poor workmanship. Sometimes I forget to mention things that I feel are a given to inspectors.
Appreciate the correction.
Jeff
Old 6/30/11, 12:51 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
Are you tell me she is here for an answer?
Would you allow installers to leave a product as she describes and let them continue the next day?
I hung siding and made money stripping aluminum and selling it for scrap.
If I see a contractor not conducting themselves properly on a site I am observing, I talk up right away Jeffery. Its easy to communicate and get the job back on tract.
Some ones hard earned money remember.
5/8 ply and 1 1/2" nails being used by the roofer.
I am there to see the first nail go in and all materials. I take photos.
Witness Jeffery.
I stopped the job ( the nailing ) and told the owner I will run for 7/8 roofing nails. Dam I will pay for a box. He was nice the job was on its way in 30 minutes.
He told the crew chief to pay attention to the decking next time.
Nail protrusions are uncalled for and a safety hazard Jeffery.
Send your child up there to bring down a box and see what can happens.
She paid for dry material. I would have the dry material on site in 1 hour or wait till all material are dried and a written extended warranty by the manufacture.
I am not a ball breaker, I can bend.
I do not like non paying members asking questions that can be answered on better sites.
We have gone through this before.
Not you and I but the ones asking InterNACHI for free advice.
Its wrong in my opinion.
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Old 6/30/11, 12:58 PM
Sorry Frank. Wrong side of the bed.
Please understand I hate that home owners get treated like slobs at times.
Old 6/30/11, 1:00 PM
Jeffery did you read Franks link.
First enlarged lettering.
Letting water get to the house wrap is like letting water get to the roofing felt. It's already too late when that happens.
Old 6/30/11, 1:16 PM
No problem. It's an uphill battle for all of us when it comes to getting everybody to treat homeowners like the worthy clients they truly are.
Old 6/30/11, 2:58 PM
Agree one hundred percent Frank. I have been dealing with clients 11 years now. Just wish they would do the same. Facade restoration Company Frank not HI.
Now frank. Wet insulation on a insulated siding left out in the rain as the installer run in the truck or cars and go home.
Would let them hang that product on your wall the next day or ask them to install a dry product like you ordered?
I see to many complications and possibilities for excess humidity buildup .
If the weather penetrated the VDB or tar paper ( hope fully VDB ) we are now talking further complications.
I have hung siding and going back some 30 years now.
I am honest. I did not learn from qualified teachers. I watched pros do it talked to them and learned the right way. 11 years ago I started to hang it right.
Old 6/30/11, 4:22 PM
Jeffery if you do not quote me on problematic post, it is easier for me to delete posts made in haste. That way there is no trace of them.
OK.
Thanks.
Old 6/30/11, 4:39 PM
OK.
Thanks.
Robert,
Quoting is MB ettiquette, so others are aware of who or what is being responded to.
Of course, there are other more devious reasons to quote someone.
If you feel you need to edit or delete a post, do so, then request I do the same.
Jeff
Old 6/30/11, 6:53 PM
Jeff
Cover walls with 1/2 inch high R Sheathing& Certainteed Monogramm over cedar shakes.
I thank everyone for their help. I will also be trying to upload pis of the Fascia board that comes down about 4 inched below gutters, & then protrudes close to one inch. To me, that could be a problem for ice build up, forcing moisture behind the walls. What do you think?
Hard board siding? sfalvey Exterior Inspections 23 11/29/10 2:41 PM
Vinyl Siding over Ship lapped Pine mtyson Exterior Inspections 10 9/17/10 10:28 PM
Vinyl siding installation guide badair Exterior Inspections 18 3/27/07 5:38 PM
