ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nice, informative,post Barry.
Here's a pic. (maybe) to go with it. This was my most recent build job.It's all vinyl,including posts and railings.I framed,roofed ,sided ,painted the interior and trimed it out myself.The rest was left to my subs. Last edited by ckratzer; 4/24/07 at 5:28 PM.. |
bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Cheremie, That's a nice big house, is that for yourself or for sale?
Weather Resistant Barrier Vinyl siding has always been designed as an exterior cladding, not a weather resistant barrier. Vinyl siding is designed to allow the material underneath it to breathe; therefore, it is not a watertight covering. Because of its design and application, it provides a supplemental rain screen that enhances the weather resistant barrier system by reducing the amount of water that reaches the underlying weather resistant barrier. What Is a Weather Resistant Barrier System? It is a system that includes water shedding materials and water diversion materials. Weather resistant barrier systems commonly consist of a combination of exterior cladding, flashed wall openings and penetrations, weather resistant barrier material, and sheathing. Effective weather resistant barrier systems will shed the water initially, control moisture flowby capillary and diffusion action, and minimize absorption into the wall structure. The level of weather resistance required is determined by the applicable building code and structure. Best Practice: To achieve designed performance, vinyl siding must be installed over a weather resistant barrier system that includes 1) a continuous weather resistant material and 2) properly integrated flashing around all penetrations and where vinyl siding interfaces with other building products such asbrick, stone, or stucco. Refer to the manufacturer’s installation manual for specific product applications and recommendations. Whichever product(s) you decide to use as part of a weather resistant barrier system, be certain the materials meet the applicable code by contacting the manufacturer of the weather resistant barrier material(s). Always consult the applicable building code for minimum weather barrier requirements in your area. Keep in mind that additional measures may provide better protection against water intrusion than the minimum requirements of the building code. ----------------------------------------- In most cases, I find the vinyl siding installed directly over the OSB. Do others find this as well? Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I built it for someone.It's on the windiest hill top on the planet.I work in all kinds of weather but it's the windy days that really make me drag *****. Personally, all I need is a little shack and a lot of open road. |
Fan fold insulation is only $38-$40.00 a "bale" and covers 3 sq.The extra cost isn't great enough to justify skimping.Although it's R-value is ,I think,about 1 it does block wind. |
Yes that's true, but I also find it with tyvek paper, and some with Insulation behind the siding
So, are you saying there is something wrong with the siding I inspected today?
bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
JohnK |
Cheremie, that's a nearly identical copy of my own home. A stock, popular plan called "Riverbend". Mind doesn't have the garage pasted on the back, though.
Are those aliens above the garage? FYI: 9850 Aberdeen, O.P. KS, Nallwood J.H., S.M. South, back in the mid '60s ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 3/25/07 at 8:55 AM.. |
You can't tell from the pic , but the garage roof doesn't actually run into the side wall. The 4/12 porch roof goes around the corner (in shadow) and further back about six feet.The 12/12 garage roof and the porch roof actually meet about three feet ,at the narrowest point,from the wall. Even still, I did pay special attention in that area because snow and rain is a big concern in areas such as that. That particular valley was fitted with 24" galvanized valley flashing,(12"on each side of the bend). The wall in that corner was flashed and counter flashed(step flashing).The step flashing alone probably would have been enough but generally I like my projects to be the best I know they can be. Marc, I don't recall the plan name.My client did buy it from a book but had it modified by an architect to fit their needs. At one time Variform ,the siding manufacturer, wanted to use it as a brochure "cover home".The home owner did not want to give permission for that so it never happened. Cheremie |
Around here they just nail it onto whatever the rotten and degraded materials were initially. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Not aliens.Something on my scanner. Not native to KS. A rural Missouri girl at heart.Although I must say when I'm finished building I'll probably move to someplace treed and hilly and build guitars for a living.I only build 4-5 a year right now. Oh No! Thread drift....Vinyl siding,vinyl siding,vinyl siding.Wait ,I don't really like vinyl siding.The alternative for this house would have been too expensive. |
| Do you unzip vinyl siding? | apfaff | Exterior Inspections | 13 | 7/23/08 9:49 AM |
| ALCOA vinyl siding one side warping, why? | Lynn Kelly | General Inspection Discussion | 4 | 5/23/07 5:32 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 5:52 AM |
| Vinyl siding window trim | jclark1 | Exterior Inspections | 14 | 6/6/06 10:46 PM |
| Vinyl Siding Install | psmothers | Exterior Inspections | 3 | 4/21/06 3:44 PM |
