Need a little help. Had an inspection this morning on a property circa 1989 wood frame construction. The original siding is a ship lapped pine that has newer vinyl siding applied directly over the original. My building science conscious tells me that a vapor barrier should have been used over the original siding before the vinyl was added but I can not find any technical data to validate. My concern is that as the siding heats up in the good old Florida sun that condensation is forming between the two sidings. Any technical advice will be appreciated.
Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Vapor barriers are supposed to go on the warm side of the wall, so I'm no so sure about installing them on the exterior. Did you see any sign of problems from condensation? If not, I'd leave that one alone.
Mark
you may be thinking of a water barrier like tyvek house wrap. It is designed to keep water/rain that gets under siding from damaging the surface it covers. It is not a vapor barrier though. |
For years, vinyl and metal siding has been installed over old pine clapboard in my area with 7500 degree days heating and essentially no cooloing degree days. Usually there was about 1" of rigid foam insulation or a WRB installed. There have been very few problems except for some installers not flashing (hidden beneath the siding) at the bottom of the the J-trim along side windows and doors. |
It's OK. You never see a vapor barrier on the outside of existing sheathing. The vinyl is less tight than another coat of paint.
Just let them know it's not original and tell them they should ensure it was installed by licensed contractors...a general disclaimer like you'd do whenever you see any new features to a home. The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life. Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
The deep south is a differant animal. check this out it was published by building science
Moisture enters building envelopes from the exterior in the humid south three major ways: rain leakage air leakage vapor diffusion Controlling these mechanisms means keeping the rain out of the building envelope, keeping exterior air out of the building envelope and keeping exterior moisture from vapor diffusion out of the building envelope. In addition it also means being realistic about the probability of success at controlling these mechanisms and therefore providing a means of drying to the interior. In practice, this usually means not preventing the normal/ typical drying to the interior conditioned space by installing an impermeable wall covering. Rain is a particularly severe mechanism of moisture transport in the humid south. When rain wets the exterior of a building the exterior surfaces typically absorb the rain water. For instance, brick cladding is a powerful rain water "sponge". Recall that moisture flow is from warm to cold. When wet brick is warmed by the sun, a significant temperature differential is created. The sun serves to "drive" rain water into a building envelope. If the interior space is also air conditioned or cooled, the air conditioning serves to "suck" the rain water inwards as a result of a temperature differential. The effect of incident solar radiation on a rain saturated cladding is dramatic. Consider that a brick veneer or stucco coating can be readily warmed by the sun well above 120 degrees Fahrenheit. The air contained in an airspace behind a brick veneer can be similarly warmed and can be considered to be at saturated conditions (vapor pressure of 11.74 kPa). This results in an increase of almost 500 percent in the effective exterior vapor pressure (Figure 3). Solar radiation is a powerful force that drives moisture in rain-saturated cladding inwards. This force can be ten times greater than the vapor diffusion driving moisture outwards under the most hostile conditions experienced in heating climates. Exterior sprinklers can excacerbate problems by wetting exterior claddings on a regular basis. The normal southern climate temperature differential then serves to move this sprinkler deposited water into the conditioned space. Masonry block (permeable) Exterior Conditions Temperature: 80 °F Relative humidity: 75% Vapor pressure: 2.49 kPa Brick veneer is saturated with rainwater 1-in. air space (rain screen, pressure equalized) Interior Conditions Temperature: 75 °F Relative humidity: 60% Vapor pressure: 1.82 kPa Conditions within Cavity: Temperature: 120 °F Relative humidity: 100% Vapor pressure: 11.74 kPa Vapor is driven inward by a high vapor pressure differential between the cavity and the interior Solar radiation stricks wall Figure 3 RR-9302:Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
If the wood siding is in decent shape you should not need a moisture barrier. That is what vinyl siding was originally made for. Then some genius decided to use it for new construction. Not thinking that every time you drive a nail through the moisture barrier, you have another spot where water can seep through. Sad but true.
Vinyl siding has always been designed as an exterior cladding, not a water-resistive barrier.
Vinyl siding is designed to allow the material underneath it to breathe; therefore, it is not a watertight covering. Best Practice: To achieve designed performance, vinyl siding must be installed over a water-resistive barrier system that includes 1) a continuous water-resistive material and 2) properly integrated flashing around all penetrations. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Yes, I just posted the link to help any that's interested in recommended installation of vinyl, and difference between vapor barrier and water resistive barrier.
I inspected a home today built in 2004 with vinyl applied directly over OSB, without water-resistive barrier.
| Hard board siding? | sfalvey | Exterior Inspections | 23 | 11/29/10 2:41 PM |
| warped vinyl siding | sgreen2 | Exterior Inspections | 4 | 10/28/09 6:36 AM |
| Composite Concrete siding Issues I need Help | rkie | Exterior Inspections | 13 | 5/1/08 7:27 PM |
