jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does anyone out there use a vinyl siding unzip tool to check flashing, dripcap, jchannel detail at the top of windows? If not, how are they checked? With this gap, how do I know if water is getting behind the siding and if it is, are the windows flashed properly? I haven't looked at houses with vinyl siding until now and theses gaps around the windows worried me a bit. Can these areas at the tops of the windows be sealed with backer rod and silicone caulk?
I don't take siding off any more than I take shingles off to look underneath. But with that said, many installers do a poor job with the windows. Do a search. Here's a start: http://www.nachi.org/forum/showthrea...ashing+windows I do pay attention to the insides of the windows, for example...water stains on a side jamb of the window or the casing would probably not be from sweating glass. |
Well yes Larry, I'm well aware of other inspection points regarding windows, but thanks for the tip. And as far as vinyl siding goes, I believe it is pretty easy (depending on the length of the piece) to zip and unzip the lap above the window. And while I realize it does go beyond standards to do this, it would give a more complete picture of the situation (especially if it was a relatively new installation where no other clues of leakage where present). If the tool and the procedure was quick and easy, and had no downside (such as possible breakage of the siding) it might be a good to be able to see these details. That's what I'm asking. Tell me, do you look under the first course of shingles for a starter course or at the sheathing? I'm interested in ascertaining all of the information that is available so I can give a better report. There is nothing wrong with going above the minimum. Now please, feel free to not refrain.
I did several searches, and was only able to find general info about flashing. Nothing that addresses inspecting techniques of the exterior details. It seems to me that using that cheapo trim piece instead of a more traditional trim, precludes the use of a drip cap. Also, I've seen conflicting opinions on whether or not the area can be sealed with backer and caulk.
Here's one method for windows that come with nailing fins as part of the unit but, especially for "hammer on" fins, I too like to see the drip cap.
The backer rod and sealant are window mfgrs. spec. Very seldom is it done reguardless the cladding. Look at page #5 Although this is pella info the same info is on most windows.
http://www.pella.com/lowes_thermasta...all.pdf#search |
Larry, nice photo. But what about builders that don't use any type of wrap under the vinyl? How much of a concern is that?
I thought James was referring to the gap between the J channel and siding. |
Larry, part of the flashing, as indicated by your picture, involves building wrap. Again, how significant if there is no paper--if you bend back the siding at the window and see wood, what would you say and is it "significant"?
I've seen that lots of times. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Is it significant?...depends, I would say, on the amount of water penetration and damage or damage potential if new. |
Steven Brewster is a non-member guest and is in no way affiliated with InterNACHI or its members.
Unfortunately, around here you see many builders installing windows onto OSB sheathing without proper flashings. Building paper (house wrap) is not required for vinyl siding (Table R703.4) but good builders install it.
Yes I will remove siding to visualize flashing if I have any concerns. To many times I find no flashings at all. Not to many applicators around here know how to prevent moisture from entering behind causing damage in the long run. |
This is with stucco for cladding. But no moisture barrier and bad flashing was/is the real problem.
http://www.badstucco.com/woodrot/indexwr.html |
| Do you unzip vinyl siding? | apfaff | Exterior Inspections | 13 | 7/23/08 9:49 AM |
| caulking around vinyl windows. | rmc3inspection | Exterior Inspections | 10 | 10/12/07 5:24 PM |
| Vinyl siding | rmacinnes | Exterior Inspections | 18 | 9/27/07 1:00 PM |
| ALCOA vinyl siding one side warping, why? | Lynn Kelly | General Inspection Discussion | 4 | 5/23/07 5:32 PM |
| Vinyl Siding Install | psmothers | Exterior Inspections | 3 | 4/21/06 3:44 PM |
