| Find an InterNACHI certified District Of Columbia Home Inspector (and anywhere else in North America) |
I have been seeing you request proof reading for these Inspection Articles but never thought to look for a place where they are grouped together till now.
Good Job! Very helpful to inspectors and a nice benefit for members to have access in way of permission to copy them . Do not know details, but hope you are feeling better. |
Thanks. Here they all are: www.nachi.org/articles.htm We produce 2 new articles a week.
Good mention of the welded corner, I saw this a lot on windows.
You mentioned alarm holes at bottom of window, not to be picky, as it's a good point. But top can be detrimental as well, a lot of manu's will void warranties upon a fastener or similar being placed in top or bottom. Some mention? Minor, I realize. I will look over again and note anything else. Another one I saw night and day when I was more active in Window Installs (1000's), was the use of Block Frame Vinyl windows, it's easy to catch where a homeowner had their windows replaced with vinyl block frame window and extruded aluminum trim or similar around sides of window. Contractors will pull window frames out of the building and slip a block frame in. Caulk it, crummy trim and you're done! Time bomb, plain and simple. Good article overall, Tim |
Some thing to add.
They have nailing flanges that never STOP moving. This causes separation of the caulking from the framing member, they then become a leak source. We cannot see this on a finished house. But what we can see when we are doing pre drywall, is if the house wrap has been installed under the nailing flange. When this is done, and the window is caulked on top of the house wrap, it is very easy for any water that penetrates the houe wrap to have a easy route into the house. Installed correctly, vinyl windows are great. Edit this down to about 10 words or less Thanks Tim |
| Please proof this new article about double-paned windows. John McKenna mentioned. | gromicko | Thermal Imaging, Infrared Cameras & Energy Audits | 16 | 11/21/10 7:38 PM |
| Collar Ties vs. Rafter Ties. Please proof this new article. | gromicko | General Inspection Discussion | 0 | 7/1/09 9:55 PM |
| Roy the proof you asked for | wdevries | Canadian Inspectors | 55 | 7/8/08 11:30 AM |
| Are electricians supposed to use these tools as per 70E? | jtedesco1 | Electrical Inspections | 27 | 12/15/07 4:40 PM |
| moisture in the bottom channels of vinyl windows | kshepard | Interior Inspections | 7 | 11/12/06 2:04 PM |
