Found this today at a 13 year old home. I first noticed a water drop/run about halfway down siding. I then proceeded to "knock" siding and more and more came dripping out. This was only in about an 8 x 8 area and no other areas did this. There was no evidence of any moisture damage and/or moisture source anywhere. What causes this? Recommendation? BTW, there was a small gap between siding joints on the back of home with bare OSB and no visible house wrap.
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You are on the south side and getting condensation or melted snow perhaps.
I saw a builder putting housewrap behind the osb once, he acted like I was crazy when I ask why he was doing it that way.
"I create controversy whether they like it or not" |
What would happen if it was on both sides?
Depends on the climate I suppose!
Crazy thought but would it stop moisture from transferring to the framing from the OSB ?
Yes OSB would rot but.... |
Recommendation?
I do not think there is one unless you took off a section to look at what is behind it to determine an issue.Siding is not a water barrier.
As long as it is not migrating to the sheathing underneath it there is no real issue that I know of and you could also post this at "your leaking house" forum.. |
If you install house wrap in 2 side it traps the moisture.
Mold, swelling of board, lose of strength, rusted hardware, etc. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
1:Look at the gutter.
They are stained. They obviously overflowing due to blockage, improper angel, etc. Water can be blown onto the siding or carried behind saw-fittings. Likely not the cause. BUT 2: Gutter nails and coils can cause a problem if not angled downwards. If the bushing, made with a aluminum wraps. ( a coil of 28 or 30 gauge )coiled aluminum 4-5 inches long and use to separate the gutter walls as the are installed into rafter ends hopefully.. If the nail is sloped upwards the water is carried onto the nail through the coil to the back side of the gutter walls that has a hole in it., So through the backside of the gutter walls, to behind the roof saw-fitting and behind the sidling. I have repaired this several time . What to look for. Nails aimed upwards , should be level of slightly downwards at 5 degrees. Look at saw-fitting for staining,( like the gutter staining ) in location of the dripping water from siding. Look up and investigate the nails. FIX reset and re-angled all nail. Take a 2 to 4 foot level and see if the gutter are aimed in the right direction. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Vinyl Siding installed without a vapor barrier (over bare OSB) is improperly installed.
Needs replacement. http://www.vinylsiding.org/installat...nual/index.asp Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Linas I am not guessing.
I am posting observations I experienced working with said product. I installed siding and roofing and repaired for 15 plus years. 3 trades 15 years Brick roofing siding. If you noticed I pointed at what to look for. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Now that I re-read the original post, Joshua mentioned that he did not observe any house wrap so Joe wins the prize for this one. No guessing.
There may be nothing wrong with using it underneath also. DuPont™ Tyvek® can be used either over or under sheathing. When DuPont™ Tyvek® is used under sheathing, it functions only as an air barrier and does not protect the sheathing as a secondary water barrier. DuPont™ Tyvek® has been used directly over studs where there is no sheathing, although use of sheathing is a highly recommended building practice. http://www2.dupont.com/Tyvek_Weather...rchitects.html |
| hydronic radiant floor heat on hot water tanks | mnicholet | Plumbing Inspections | 7 | 4/14/10 5:48 PM |
| Site grading and drainage | wdevries | Canadian Inspectors | 5 | 10/6/09 10:23 PM |
| What might cause this many cracks? | bhamilton | Structural Inspections | 15 | 2/25/09 12:44 PM |
