7 year old house. In the spring when the snow is menting they get water dripping just out of the front door. The house faces to the north with an open street. They clame that there is no water in the summer when it is raining. Is this snow that gets into the soffits or has anybody had this problem.
![]() Thanks Lawrence |
http://www.townwoodhomes.com/care_servIceDam.htm ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Very possible. Do you think it would help if there was roof vents in this part?
Lawrence |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
So you could add soffit or Gable down low if possible, can not see ends. When re-shingling I think it might be a good idea to cover it with Ice and water shield before shingles to the whole thing. Do not forget the drip edge. I also would install a barrier at the end of Velley to stop water overshooting the Gutter NOW! ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
What is the slope of the roof? How much snow is there when the leak happens? There is a chance of ice damming but this usually occurs more outward within 1-3 feet of the roof edge unless there are special circumstances of very heavy snow buildup. Facing north, I might expect that snow may tend to blow off a roof from the prevailing roofs. Since it faces north, could be a chance of fine snow blowing into the soffits. Or could it be an air leak that caused a build-up of frost during the winter and then melting when it warms up. I have seen a few of these during my career. Need more info. |
don't know who drew that diagram. It does explain what is happening but the graphics are off a bit....lower slope roofs 5-6 in 12 and lower are usually the problem: -the diagram roof slope is 12/12. Unless there is a very special situation, water usually doesn't back up much against that steep a grade. In fact, the NBC does not require eave protection such as Grace "Ice and Water Shield" after the slope is steeper than 8/12 as ice damming is generally not a problem on roofs steeper than that. I've asked roofers who are applying eave protection on slopes 8/12 or greater "Why are you doing that?"......answers: "It's Code!!" I would like to them say once "We're doing a better job and going over code." Would start me having some confidence in them!!! |
Either way, you raise some good points and certainly more info would be helpful. |
Still stick with my previous post. ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Yes, it could be ice damming. |
The slope in this picture may have been exaggerated (steeper) to get all the information (text/drawings) in the space between the roof and the ceiling. my .02 |
Remember, putting those lights in the soffit adds heat to the interior area, which will speed melting.
Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Thanks for all of the help. Have been away from the Internet for a few days so trying to catch up.
The Ice Damming is a great possibility but the snow going into the soffits might be better idea. This is happening in the spring. No snow on the roof. There is about a 4 foot overhang here. From my what I remember (no side picture) the roof runs off the side of the house. It is not connected to the house other than on the side of the wall. Here is another picture of under the veranda. The water is coming just to the right of the light. ![]() Correct me if i am wrong but ice damming only occurs when there is snow on the roof. Or can it happen in the winter and not know until the spring? Thanks Lawrence |
Got there at Noon , I was on the out side Char on the inside , She called me in to show water leak looked like it had just started , Called agent . By the time he got there is was a good flow second agent arrives and they move furniture get mop buckets ect. Yes it was strictly ice damming had not leaked until it got warm out side . Yes the client bought the home Roof unfixed $10,000;00 reduction in price. The client and agent both phoned 3 days later to thank us for our inspection and help and to tell about the price reduction. ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Thanks Roy
Lawrence |
