WHAT DOES THIS LOOK LIKE?
THE SURFACE IS WAVY, BUT INSIDE THE ATTIC THE PLANKS APPEAR FLUSH.. Am i right to suppose there could be a problem with the UNDERLAYMENT?? How should i write this one up?- ( also consider part of the roof is covered in snow) Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like multiple layers of shingles Joe...
No nails showing on the underside either. Nails too short, and starting to pop possibly, and multiple layers, equals wavy.
Good observation Ian- that hadn't occurred to me yet for some reason,
Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Multiple layers. The vent appears to have it's flange buried, as opposed to the pipe collar.
Nails aren't supposed to come through planks. That's a plywood requirement due to it's lack of holding power. |
Thanks Frank, you are right on the planking. My bad.
As an expert, would you comment on this thread, please. Thanks. http://www.nachi.org/forum/f16/multi...19/#post623757 Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
In your second photo, I am seeing edges of the horizontal side of the plywood and the first photo appears to show waviness along the horizontal line. Some of the plywood panels appear to be narrower than four feet wide and do not have H clips. All of these could be contributing to waviness, although I would not disagree with multiple layers and nail pops. That WAS a cool observation Ian.
It's gotta be wavy due to multiple layers of roofing.
Joseph, were you able to pull up the shingles at the overhang to check for multiple layers. Matthew, it's planked boards not plywood so that's why there is no ply clips. Out of couriosity how old is this house? Off the subject, It looks like another older house where they used the foundation form material for roof framing material. Isn't that a concrete film on the rafters and bracing? Joe Keresztury JWK Inspections Home Inspections in San Antonio, Schertz, Cibolo, New Braunfels, Boerne and all surrounding South Texas areas www.jwkhomeinspections.com |
Roof waving is caused by many factors, some mentioned here. Poor quality shingles is another. Shingles installed tightly on a cool day can cause waving when the roof gets hot, and the shingles expand. Lack of underlayment (tar paper), multiple layers, weight of a previous snow fall, etc.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
The Home was built in 1940. That very well could be concrete film on the rafters- that crossed my mind. Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
Typical of a roof with multiple layers, especially one with comp shingles installed over wood shingles. Look closely at the edge of he roof.
I would think multiple layers also. but were there any ventilation in the attic. looking at pic I don't see alot and that's a good size area
Kisers Home Inspections http://www.inspectorpages.com/jkiser http://activerain.com/jimekiser http://www.kisershomeinspections.com |
Multiple layers.
Alabama Home Inspections www.thebirminghamhomeinspector.com Home Inspections in Birmingham, Montgomery, Huntsville, and Tuscaloosa. |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 3:59 PM |
| Before You Start Repairing or Replacing Roof Finishes from CMHC | mkyriacou | Canadian Inspectors | 0 | 9/17/09 1:52 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
