Old 7/29/10, 9:59 PM
Joe Funderburk, CMI's Avatar
Question Weep holes drilled after the wall is complete?
Anyone ever heard of that? I swear that's what I think happened, even though the builder's rep. denied it (new construction). I was there before the walls were pressure washed, before landscaping.
Note the chipped bricks and the brick dust on the soil beneath the weep holes.
What would you say about the potential ramifications and what would be your recommendation?
weep-holes-drilled-after-wall-complete-072930-220.jpg weep-holes-drilled-after-wall-complete-072930-217.jpg weep-holes-drilled-after-wall-complete-072930-216.jpg
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/29/10, 10:30 PM
Christopher Currins's Avatar
Default Re: Weep holes drilled after the wall is complete?
Where's the flashing?
Christopher Currins
Certified, Licensed
Old 7/29/10, 10:32 PM
I assume it's behind the brick with holes in it now.
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/29/10, 10:39 PM
Bob Elliott's Avatar
Looks like CMU straight into the earth.
Where is the foundation ?
The developer is a lier too.
Were the lintels and areas above doors flashed and weeped?
Old 7/29/10, 10:41 PM
Good questions.
The areas above doors and windows were pencil sized and there was no evidence of drilling there.
This is a slab home. Drilled holes were at the slab foundation.
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/29/10, 10:42 PM
Bob, side question...
How do you tell if a door is flashed after construction is complete?
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/29/10, 10:55 PM
It's recommended to extend flashing to the face of the brick.
Anyway you can definitely tell the holes are fresh drilled. It wouldn't by chance be for pest control?
Christopher Currins
Certified, Licensed
Old 7/29/10, 11:00 PM
mnahrgang's Avatar
My guess is that they left them out, and the AHJ caught 'em. It was this or tear the wall down and do it right. If I were the AHJ, I'd tell em "no dice". Once the wall is built wrong, no amount of drilling "weep" holes will make it right. I know some people recommend "installing" them, but it requires removing multiple rows of bricks, installing proper flashing, and re-installing the rows... even then that is presuming that there is a proper vapor barrier.
Mark Nahrgang
www.HeyMark.info
Old 7/29/10, 11:03 PM
Since that is CMU you should see it at the steel lintel above the door frame along with the wicks and at least about "1/2 of moisture barrier sticking out underneath the wicks.
Once again here is what I go by.
Any building constructed since 1970 should have rubber, plastic or metallic "flashing," a protective skirt that curves around joints to protect against moisture. When water does get through a wall, it collects on the flashing and is released through "weep holes," small openings in the masonry. These holes are most obvious at the top of the foundation wall.
3/16-inch-diameter weep holes every 33 inches at minimum, just above the flashing . Flashing, in turn, is recommended under the first course of masonry at ground level, above windows and doors, below window sills, and at any lintels and shelf angles .
Old 7/29/10, 11:06 PM
Not pest control holes.
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/29/10, 11:27 PM
Bruce A. King's Avatar
My house is 8yr old full brick on a slab, no weep holes, no problems.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 7/29/10, 11:28 PM
FLASHING
Christopher Currins
Certified, Licensed
Old 7/29/10, 11:29 PM
Well, if I inspect you're house, I'll let it slide.
But what would you say in this case of new construction?
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/29/10, 11:38 PM
I include with every report on a brick house that the presence of or proper installation of weep holes is not inspected and that even if they are present they will be blocked on the back side by loose falling mortar. Watch some masons for awhile and you will see. It can't be corrected without more expense than anyone will take on anyway.
704 301-3207
Old 7/29/10, 11:41 PM
Side note: So you don't confirm proper installation, but do you call out their absence?
Theodore Roosevelt
Joe Funderburk, CMI
Brick veneer flashing mklein Exterior Inspections 6 2/21/10 4:20 PM
Weep holes & J-trim yolban AskNACHI.org Inspection Questions Forum 0 10/21/09 2:50 PM
Congratulations to PHPIO... Ontario's new home inspection association. gromicko Canadian Inspectors 60 10/22/08 8:07 PM
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
If someone can get me CAHPI's and OAHI's I'll add them... gromicko Canadian Inspectors 72 4/7/08 7:39 PM
