This is the first for me but I can the reason. Has anyone else come across this and why it was done? The photo is of a new construction.
Frank Magdefrau Certified Master Inspector DeSoto Home Inspection Services, LLC 3152 Big Ben S Hernando, MS 38632 (901) 486-0421 InterNACHI Member since 2002 InterNACHI message board member since 2003 InterNACHI ESOP member from 2004 to 2010 |
If there is flashing behind there as there should be, then a weep hole (or holes) is necessary. What's the point of installing flashing to control water, if there is nowhere for the water to go?
It may look out of place if the rest have wicks , but we are not seeing the rest.
I would worry if not every 24" though I think 36" is max allowed in some cases. They may have left a larger slot due to lack of wicks since they are used to make up for all the spilled mortar which blocks the opening. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 8/6/08 at 8:12 PM.. |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
And then you have contractors who just don't install weep drainage. Above windows, where veneer meets foundation, nowhere at all..
What about the lack of backer rod and sealant joints that most window mfgrs. call for between the windows and bricks?
"I create controversy whether they like it or not" |
You guys are great and I leaned allot today. I just don't understand how after 2000 inspections this is the first time I have ever seen weep holes over doors and windows.
Barry, thanks for posting this.
When is a vertical expansion joint in brick veneer required? I typically see these joints in commercial inspections with 30 ft walls that have about 42-45 bricks. |
| Weep Holes over Window and Doors | chunt1 | Exterior Inspections | 5 | 1/21/08 8:19 PM |
| Brick-Veneer Inspection Guide | jbowman | Exterior Inspections | 12 | 1/8/07 9:20 AM |
| Weep holes | dmacy | Exterior Inspections | 3 | 12/4/06 7:12 PM |
