| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
I saw this this morning on a new construction. Weep wicks were installed on third course of brick. None on bottom course. Why??
Linas Dapkus Lockport,Il. 60441 #06012294 Chicago Home Inspector Chicago Home Inspection Chicago Home Inspector Linas Dapkus My Chicago Home Inspection Chicago Home Inspection Today |
Hi. Linus;
The only time I see that is when there is a brick shelf in the foundation/slab and the cavity behing those three courses are grouted and the flashing and weep are installed at that level. Some install it at finish floor elevation, but I prefer to have it one course down. Since I can not see the whole picture, this is an assumption. Where was the finish floor relative to the first course of bricks in your photo? I added this link for references; Figure; 3 on http://www.advancedflashing.com/clie...Note%2028b.pdf Hope this helps a little. Marcel Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ Last edited by mcyr; 7/27/08 at 3:01 PM.. |
I really didn't go back into the home to investigate further. This was a second draw inspection on this home and I will investigate further on the next inspection. It had blown in cellulose wall insulation and some closed cell urethane foam insulation in different areas. I have only seen foam and blown in exterior wall insulation in maybe 3 out of 500 draws in the last 12 months.
| Sump Pit/Pump Question | Joey D'Adamo | Plumbing | 4 | 11/26/08 2:04 PM |
| "UFER" Ground? see last paragraph. | jtedesco1 | Electrical | 6 | 9/15/08 8:57 AM |
| To weep or not to weep! | rgant | Exterior | 14 | 2/15/07 1:40 PM |
| OK, Be kind. Newbie with alot to learn. | rcarley | Electrical | 23 | 12/3/06 3:00 AM |
| Plumbing vent Routing Question | kweiss | Plumbing | 7 | 11/1/06 10:57 PM |
