Old 12/22/08, 10:48 PM
Tom Yeager Tom Yeager is offline
Default Weeping siding?
1995 colorado home. East side has three different areas where there appears to be water stains (dry at this time) coming from under the siding. On the interior living room windows, same side, there is water damage (dry at this time.) Structural floor dehumidification system is broken and moisture is found on ALL the walls, but the east wall is pictured. Unable to verify gutter system, too high for a ladder and too dangerous to walk.
One problem? Two? Three separate problems?
Who should I refer this one to? Structural engineer?
Any comments are welcome!
weeping-siding-pc220051.jpg   weeping-siding-pc220052.jpg   weeping-siding-pc220053.jpg   weeping-siding-pc220063.jpg   weeping-siding-pc220111.jpg
Tom Yeager
Owner/Certified Inspector
Inspect-It 1st
303-464-9090
www.tyeagerinspects.com
NEHA Radon Certification # 104169 RT
NACHI Certified Home Inspector
Old 12/22/08, 10:53 PM
Carl A. Brown's Avatar
Default Re: Weeping siding?
Rotting OSB?
IR inspection would/could really help.
Old 12/22/08, 10:54 PM
Any idea what is on it for moisture barrier?
Old 12/22/08, 11:15 PM
I like the IR idea. No vapor barrier on floor (common in CO) unverifiable in the wall.
Tom Yeager
Inspect-It 1st
303-464-9090
Old 12/22/08, 11:24 PM
Dale Duffy's Avatar
Structural Engineer is for just that, engineering something of a structural nature, like Carl said an IR Scan would be a start, but I bet that whole house has rotted OSB every where, should have a contractor pop some siding off to see what degree it has turned to sawdust to begin with.
Then the ventilation issue, well, hard to remedy without being there to see the WHOLE picture....definitely a mess though.
Old 12/22/08, 11:30 PM
Your Leaking House--))
Your Leaking House Message Board
Old 12/23/08, 12:23 AM
Tom,
What is the siding material?
Old 12/23/08, 12:38 AM
Hardboard (composit made to look like wood)
Tom Yeager
Inspect-It 1st
303-464-9090
Old 12/23/08, 12:49 AM
Barry Adair's Avatar
Moisture/condensation visibly verified interior, exterior, basement/crawl no need for IR to confirm what is evident. IMO
Consult a siding contractor to remove siding, evaluate for structural damage, submit estimate for proper re-installation and other required repairs, by the book for your region.
The apparent originating source humidity problems will also have to be addressed, possibly a building science design expert. All depends on what dehumidification systems are in place currently and what requires repair/replacement.
All should occur prior to closing...otherwise they're just purchasing someone else's problems.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/23/08, 1:03 AM
Barry - THANKS!!!!!!!! - Tom
Tom Yeager
Inspect-It 1st
303-464-9090
Old 12/25/08, 5:38 PM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Barry beat me to it. More than just an exterior issue.
Reckless comments incriminate sellers in home siding suit gromicko Exterior Inspections 2 2/26/08 11:44 PM
Asbestos Siding jwisecup Exterior Inspections 18 11/9/06 7:11 PM
Siding recall? slarosa Exterior Inspections 1 10/3/06 2:11 PM
