Is this cover on the roof related to the pool? The pool pump is directly below the flex pipe. Is it some type of solar hetaer for the pool?
Thanks Dave |
Im assuming that you are talking about the Solar Panels?
Paul
Is the solar panel to heat the pool? Never seen this set uop before. How does the panel hook up to the pool controls to heat the pool? |
Those are simply, small black tubes/tubing. The pump system is connected directly to this (no electricity other than at the pump).
Generally, there is a bypass to run the circulation pump without adding the heated water to the pool/spa. Very common in CA and a complete eye-sore if you ask me. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
David,
Ditto what jeff said Keep in mind that those types of solar systems are not only an eyesore but a maitenance nightmare as far as keeping debri from building up around and underneath. Although some areas allow the flexible piping its not a good idea in my opinion. Most of the ones that ive encountered have been hard piped. I would find out the who the manufacturer is of that system and pull up the installation guide online to verify that it was installed correctly or refer it out to a licensed contractor. Hope this helps. Paul Pendley Premier Property Inspections |
Steve Boozer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I was gonna say that solar system looks like crap up there, but I think that would be a compliment.
InspectorDana is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is not uncommon here in California. They are unglazed solar panels for heating the pool. I would check the installation manual to be sure they were properly installed. The workmanship on the connection piping is very questionable. (looks like s**t)
Unsightly they may be but it sure beats paying the $100+ per month to heat the pool. (I once forgot to turn off the pool heater after inspecting and got a $600 bill three months later. My fault, I payed) It does appear that they are on the back side of the roof, not visible from the street. Sometimes function is beauty! |
That is the most common form of pool heat we have here in FL. They are common for leakage around the anchor bolts (look for rotted or stained roof sheathing in the attic), and the small tubes frequently leak at their connection to the collector pipes.
| Panel Cover Screws | mhawley | Electrical Inspections | 17 | 4/24/07 5:23 PM |
| Warm Light Switch Cover | cpennick | General Inspection Discussion | 11 | 11/23/06 12:05 PM |
| Live weather cover | jnicholson | Electrical Inspections | 13 | 10/31/06 11:31 PM |
