Old 2/22/10, 5:41 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default What's your narrative on this one?
whats-your-narrative-one-ice-dam-ben-gromicko-.jpg whats-your-narrative-one-ice-dam-ben-gromicko-b.jpg whats-your-narrative-one-ice-dam-ben-gromicko-c.jpg whats-your-narrative-one-ice-dam-ben-gromicko-d.jpg
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/22/10, 5:43 PM
Bob Elliott's Avatar
Default Re: What's your narrative on this one?
Cause is most likely lack of proper insulation in the attic .
Result of heat from the home melting snow and then refreezing as ice at the gutter.
(I find myself noting which neighbors need insulation all the time.)
Temperature in the attic should be close to the outside as possible.
think of the air between the roof and top of the insulation as an open umbrella.
Old 2/22/10, 5:51 PM
Doug Edwards,  CMI's Avatar
I can honestly say I have never written up anything on an ice dam. Leaf dam, yes, ice dam. No.
- John Stuart Mill
Old 2/22/10, 6:02 PM
Brian E. Kelly's Avatar
ditto.
Client has made ill advised decision to live where it gets fricking cold. Recommend consultation with Licensed Meteoroligst and Registered Cartographer as to best geographic locations to to avoid such conditions in the future.
Old 2/22/10, 6:19 PM
Mover farther south.
Old 2/22/10, 7:05 PM
Jeffrey R. Jonas's Avatar
Okay, now we're really gonna find out who lives and work's in the North!!!
Bob, although you are correct...sometimes... it is not always the case.
Sometimes it is caused by the weather patterns themselves. And gutters.
In my area, today, you can drive around town and find the same condition on 99.9% of the homes. The homes that do not show this, generally do not have gutters. Also, homes that have been vacant over the winter (heat off) are exhibiting the issue.
So what's happening???
A month ago, most homes did not have any significant ice damming. What has changed is the weather. We have been having temperature swings anywhere from -10f at night to 35f during the day. During the day, the snow is melting and then refreezing in the gutters. As each day passes, since the ice does not melt as easily as the snow, the ice builds up. When the gutters are full of ice, they overflow, and create the ice dams. The roof exposures to the East and South are exhibiting this much more than West and North facing.
Note: the homes with gutters, that also have leaf guards, are twice as worse as those without guards.
Old 2/22/10, 7:07 PM
gotta be lamest "Narrative" so far.
Old 2/22/10, 7:15 PM
Bobby Hamilton's Avatar
Bobby Hamilton Bobby Hamilton is offline
The same has been going on here as well. I knocked off some nice 6 foot icicles hanging off my gutters recently. We've had a lot of gutters falling off houses around here recently
Bobby Hamilton
Bloodhound Home Inspection Services
Youngstown Home Inspection
Austintown Ohio Home Inspection
Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Old 2/22/10, 7:22 PM
Not a narrative, but education for those that assume the only cause is as Bob described.
If you look closely at Ben's pictures, you will see the ice buildup in the gutters, and the snow on the roof is not melted in patches, as is typically the case in heat loss.
When the condition exists as I described, I do not have a narrative. I make note of the condition, and explain verbally to the client the cause. For the stated condition, there is no cure. Except to move South, as others have advised
Old 2/22/10, 7:25 PM
I sometimes wonder how many inexperienced inspectors write-up as a defect the withdrawn gutter nails, without understanding that the "glacier" is pulling them out as it travels downward. Should always use screws in the North, not nails.
Old 2/22/10, 7:28 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
I have to agree with Jeff. With the temp swings we see at this time of year around here that is pretty common. Heat loss can be a contributing factor but it is not the only cause.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/22/10, 7:32 PM
Christopher Currins's Avatar
Exactly! Same in my region. Exterior temperature change and solar heat that no attic insulation/ventilation system can prevent.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 2/22/10, 8:46 PM
jkiser's Avatar
jkiser jkiser is offline
Especially if the overhang is 16" or more very common on weather conditions regardless of attic insulation. all the more reason to use ice guard on roofs.
Old 2/22/10, 9:16 PM
Marcel Gratton's Avatar
For The Record: We observed ice damming on the roof. The potential for ice dams varies with the severity of the winter and depending on insulation and ventilation under the roof. Severe ice dams can result in leaks, typically near the eaves. Solutions include better attic insulation and ventilation, eave protection below the roof coverings, or as a stop-gap measure, the installation of heating cables on the roof.
On The Level Inspection
Gatineau, Québec
Old 2/22/10, 9:24 PM
James F. McKee's Avatar
my narrative....welcome to Ohio...it is winter here....you're gonna have that....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Does anyone have a good narrative on "slugging"? jlevy1 Inspecting HVAC Systems 6 1/29/10 6:11 PM
