![]() In the above picture, the "stucco" meets the manufactured stone in three different ways. Caulk, grout, and flashing. Which is correct? Which is a concern/defect that may cause major water problems?
![]() According to the InterNACHI Standards of Practice, and inspector is required to INSPECT the siding and flashing, and DESCRIBE the exterior wall covering. ![]() What if the next house you inspect has stucco or EIFS? There are over 12 types of stucco and EIFS. Can you INSPECT and DESCRIBE them as required by the Standards of Practice? << The BEST non-invasive, visual-only inspection techniques (free video) >> |
| Find an InterNACHI certified Indiana Home Inspector (and anywhere else in North America) |
You are correct. But why assume that it is a MD-EIFS (moisture drainage EIFS)?
At the intersection of the "stucco" and manufactured stone, does visible flashing always have to be installed? |
I understand that is the common but not better technique. |
Robert brings up a valid point; looking at the surface of the wall do we have enough inforation to decide what is correct? Some of the questions that come to mind include:
How are the moisture barriers and lath installed?
Did the same crew do both applications? No one knows. "I create controversy whether they like it or not" |
Depends on building "code". This is where it is good to know and understand "code" and proper "construction standards" related to building materials and installation specifications.
In Canada - yes, flashings are required at change of materials (edges) on exterior. Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
| correct roof penetration | rperkerewicz | Electrical Inspections | 8 | 1/28/12 11:20 PM |
| Is this correct | rchorey | Electrical Inspections | 24 | 11/2/08 12:34 PM |
| near correct condensate drain | bking | Inspecting HVAC Systems | 2 | 9/19/07 1:51 PM |
| Correct connect at Furnace | tmartens | Plumbing Inspections | 2 | 5/1/07 9:33 PM |
