I've seen some different numbers when in comes to egress size for bedroom windows... but does this include removing a sash? or both?... i have a newly constructed home with a bottom openning size of 38" wide by 14.5 high... of course double that if you count removing the sashes...
anyone have different take on this? there is a casement window in same room that is taller but only about 18" wide... Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
do you interpret that as without removing the sashes? ex. double hung windows?
rgrizzle is a non-member guest and is in no way affiliated with InterNACHI or its members.
yes that is clear opening, not tools or tools to operate. no removal
When you say remove the sashes, do you mean they come completely out? The ones I have seen are attached to counterweight or some type of hardware. They are for emergency escape. Who's going to know to remove the sash in an emergency? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
yes these are simple anderson windows... the sashes pop right out... for cleaning...
that was my interpretation as well... someone may not know how to removed... but i wanted to be clear before i wrote it up... i showed my clients how they operate none the less... Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 Last edited by jcampbell; 8/13/08 at 11:47 PM.. |
by the way that photo is not stretched.. .that is how they look...
I right them up as questionable egress window not meeting current accepted building practices and to check with local fire and safety officials for current requirements.
It 20" min height in my area and 5 sq ft. Neither of which his window meets. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Someone do the math, I gotta go....
38" wide by 14.5 high |
3.826 sq. ft. for Mr. Campbell's window and several of your's are less that 5 sq. ft. too. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Hi. Jeff;
Here is my take, Section R310 The net clear opening dimensions required by this section shall be obtained by the normal operation of the evergency escape and rescue opening from the inside. R3010.1 Minimum opening Areas. All evergency escape and rescue openings shall have a minimum net clear opening of 5.7 square feet. exception; Grade floor openings shall have a minimum net clear opening of 5 square feet. R310.1.2 Minimum opening height. 24" R310.1.3 Minimum opening width. 20" And those are clear openings. Window size of 38" x 14 & 1/2" = 3.83 sq. ft. in clear area. So by the letter of the IRC it does not meet that code. I believe these same requirements are listed under the NFPA 101. I would check and see if the local jurisdiction enforces this or have their own requirements. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I inspect in Minnesota and Wisconsin. The requirements I gave are for Minnesota. Wisconsin is a bit different in that in only requires the 20" and 24" minimums irrespective of height and width for bedroom egress and does not requires 5 sq. ft. minimum clear space. The 8% natural light requirment is also required. A typical 12 x 12 room would need 11.52 sq. ft. of window area. So if there is only a single window it would still likely meet the 5 sq.ft. clear area. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Bedroom Window Egress | dshock | Structural Inspections | 17 | 7/16/10 9:18 AM |
| Egress Window Well | jhagarty | Exterior Inspections | 27 | 12/22/07 10:01 AM |
| egress window well retaining wall | Ivor Findlay | Structural Inspections | 4 | 5/23/07 10:03 AM |
| CPA of Health Canada reminding us of corded window coverings. | gromicko | Canadian Inspectors | 7 | 4/23/07 7:31 AM |
