Old 10/25/07, 3:47 PM
lfoster's Avatar
lfoster lfoster is offline
Question Window flashing --
I need some clarification, please: wording of the 2006 IRC.
703.8 (1) states the flashing is to extend to the surface of the exterior wall - or to the water resistive barrier for drainage.
703.8 (4) says flashing shall be installed continuously above all projecting wood trim. -- I would assume (bad choice of wording) that 703.8(4) refers to wood trim other than at doors and windows ?
Flashing has not been installed above the window trim in the photos. A drip cap appears to be part of the upper window trim / inner seal.
Do you call this type of installation?
or include in comments?
Thanks,
Linda
Old 10/25/07, 4:20 PM
Carl A. Brown's Avatar
Default Re: Window flashing --
Did they have kickouts?
Maybe recomend an IR inspection?
Old 10/25/07, 5:26 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Linda,
Many builders are doing that around here----where the flashing installation is as it should be if the trim weren't there. They see the trim as "ornamental"--disposable in a sense. I agree that the trim above the window should be properly flashed. It is usually just caulked. I recommend that the caulk be maintained or proper flashings installed to prevent water from getting behind the board. Sooner or later this type of installation can/will lead to problems.
Old 10/25/07, 5:33 PM
ldapkus ldapkus is offline
Here are some pics from a moisture intrusion inspection on a brick home where the caulk that sealed the window frame to the lintel had shrunk and allowed water to come in and migrate to the basement. The builder couldn't find the problem and was dependant on my results. Home is about 15 months old.
ID:	15526   window-flashing-ir_0036-small-.jpg.jpg
ID:	15527   window-flashing-pa180068-small-.jpg.JPG
Old 10/25/07, 5:44 PM
rwand1 rwand1 is offline
Linda,
Yes I would call out a drip cap is missing on the first picture 100_9754b.jpg
The second photo appears to have a large overhang negating the need for a drip cap.
Old 10/25/07, 5:45 PM
Linas.
No moisture barrier?
Old 10/25/07, 5:56 PM
Barry Adair's Avatar
Originally Posted by cbrown1
Linas.
What's that?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/25/07, 5:58 PM
Linas.
I guess not. Moisture came in on upper level and worked its way down the interior of the wall and ended up in the basement. The mortar weeps were gouged out after the brick was laid. What's a moisture barrier?? "No habla egles"
ID:	15529   window-flashing-p9290001-small-.jpg.JPG
ID:	15530   window-flashing-p9290011-small-.jpg.JPG
Old 10/25/07, 6:03 PM
I often wonder what this one looks like the pics are about 3 years old.
http://www.badstucco.com/bricks/bricks.html
when I took the pictures it could have been fixed I called an OVPKS. codes official and he would not do anything about it.
Allright Barry! You know what I am talkin bout!
When everyone is talking about caulk joints why don't they mention backer rod?
Old 10/25/07, 6:06 PM
And everyone needs to be on the look out for FAUX flashing!
http://www.badstucco.com/ff.html
Old 10/25/07, 6:16 PM
Linas,
A good chance if it had a house wrap on it the pulled it in at the head of the lower window instead of over it. As per the leader of the crap wraps instalation specs until a couple years ago! (tyvek) DUPONT And I have heard tell cement eats tyvek up anyway!
If the bricklayer used tarpaper he put it on over the bottom nail fin of the upper window makeing a funnel.
Old 10/25/07, 6:18 PM
Bad wrap examples.
http://www.badstucco.com/housewrap/HOUSEWRAP.html
Old 10/25/07, 6:21 PM
Linda;
Some of the illustrations in this link might help explain how some of this exterior trim should be executed.
http://www.windsorone.com/windsoronefull.pdf
Hope this helps.
Marcel
Old 10/25/07, 6:24 PM
The owners said they watched the construction and Tyvek was used.
Old 10/25/07, 6:37 PM
Linas,
They also say to tape all the joints on the tyvek and that traps moisture in the assembly once it gets in. It also traps moisture in thats from in the house trying to get out. ie: vapor after it condenses! In the winter time for you and me. OSB for sheathing?
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
caulking around vinyl windows. rmc3inspection Exterior Inspections 11 10/12/07 4:24 PM
Window well finishing rmuller Interior Inspections 7 5/10/07 8:11 PM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 7 4/23/07 7:31 AM
Window installation jmichalski Exterior Inspections 17 1/24/06 9:42 PM
