jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is it acceptable for a window installation (new home construction) to be installed in the folllowing manner: Vinyl window installed, THEN edges on exterior sealed with 3" foil tape serving as flashing all around? (then vinyl siding placed over)
As far as I was aware, I thought 4 inches of overlapping flashing were required to be installed BEFORE the window was put in place... This was confirmed by every window installation source I could find, but I thought to check here to see if maybe it was technically allowable (although not recommended). Before I make the builder fix every window in the home (28 of them) I thought I would check first. I could not find tha name of the manufacturer name, or I would just cite their instructions. |
Its not uncommon to tape around the window, however, there are additional aspects of the installation that have to be required.
INSTALLING VINYL SIDING
The sill flashing is done before but the sides and top/head flashing is done after the window is installed.
Click on "flashing window using house wrap" or "flashing window using building paper". http://www.apawood.org/bbh_walls.cfm Last edited by lkage; 1/13/06 at 8:08 AM.. |
Thanks, Larry. Unfortunately, there is no home wrap or building paper anywhere near this house. Just foil tape around the window installation which, it appears, would guide water under the siding to the unprotected sheathing.
OK - just checking. I think what I was looking for is the building paper installation. Usually where is see this, the window area has the building paper installed, then the window, then other flashing. |
Joe:
I have found this many times where the perimeter is taped without flashing. (a Toll House?) It does not meet the design of any of the window manufacturer's recommendations that I have reviewed. Example: See page 4 http://www.jeld-wen.com/_pdf/JII001.pdf Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 1/13/06 at 8:44 AM.. |
Thanks, Joe.
I know it isn't to spec with manufacturers ( I checked a lot) and the lack of any underlayment violates the vinyl siding specs as well (also the recommended procedures of the vinyl institute). It isn't a Toll....it's a small Berks Co. builder called "Hearthstone". It is in a new development where several buiders are building...only Hearthstones have no home wrap, step flashing installed after the roofing is in place, and items like this kind of window flashing. |
Carl Brown is a non-member guest and is in no way affiliated with InterNACHI or its members.
Then it will look like this!
http://www.badstucco.com/repair2.html |
And in new construction this is being used in the kc metro!
http://www.badstucco.com/ff.htm |
Doing construction phase inspections I use the spanish dictionary far more than any other tool...... |
Dale,
We have plenty of those subs here too (several rumors and over-generizations about their citizenry, etc abound, but I can't subtantiate so I will not repeat them). A builder's quality is only as good as the work of the subconactors and the attention to detail of his project manager. For what it's worth, I think Toll Bros. is one of the better builders in this region as well, in most cases. Like I said, bad subs abound.... |
Joe,
Read the window manufacturer's installation instructions for proper installation techniques. They vary by manufacturer, but most require a minimum 4" tape or flashing. Regards, Russell G. Cloyd Intra-Spec Home Inspections & Code Consulting, LLC 859-586-4591 www.intra-spechomeinspections.com |
Thanks, Russell. I have researched many window manufacturers to find exactly what you have mentioned - they all require 4" overlap, and all speak of underlayment or wrap of one type or another....
In this case, and as I am finding is increasingly popular among builders, the manufacturer info stickers are missing (torn off at installation) and the info is not present anywhere on some of the lower-end windows. So, without a specific manufacturer, it is hard to say, but calling it out and recommending installation as per factory specs may get it done.... |
The preferred method around here is to use Vicor which is the same prodout as ice and watersheild, and comes in widths that you desire. A strip of Vicor is installed under the sill, before the window installation, and then a Vicor strip is installed on the sides and the top. Consequentlly, the building paper is installed over that. This is a common practice and approved by most Window Manufacturers. Hope this helps. Marcel |
Thanks Marcel. That's pretty much what I come up with everywhere. What happens when there is no wrap or building paper is another issue I get to contend with now.....
Incidentally, here is the picture......
| Window well finishing | rmuller | Interior Inspections | 7 | 5/10/07 8:11 PM |
| CPA of Health Canada reminding us of corded window coverings. | gromicko | Canadian Inspectors | 7 | 4/23/07 7:31 AM |
| Window installation | cbrown1 | Exterior Inspections | 10 | 3/8/06 5:54 PM |
| Flanged window installation | bnelson | Exterior Inspections | 6 | 1/30/06 7:01 PM |
