What you think about this window, MDF and quarter round.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Look at the nails. The MDF has already sucked moisture 'til it swelled around the nails. Poor material covering up some other mistake would be my thought.
MDF is not recommended as an exterior material !!
Hell I don't recommend it as an interior material, it's like a sponge even hi humidity makes it swell. |
I know, it is amazing!!! Thanks!
No way to tell if flashed properly though.
Designed to last as long as it takes the installer to get out of the driveway and down the street.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
I think it is probably leaking.
OK
What is supposed to be behind that wood.? What do you think is behind that wood or should I say sawdust and glue.? Lets pull out the diagrams. |
"I create controversy whether they like it or not" |
Thanks Bob.
Face applied trim to T-111, guaranteed it is leaking. No signs of flashing there.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Need help flashing top of replacement window on brick wall !!! | Bill Featherstone | Exterior Inspections | 5 | 6/26/10 11:25 PM |
| Saturated Window Facing Trim | jevans | Exterior Inspections | 1 | 9/24/09 7:49 AM |
| Leak in bay window with copper roof | hmiles | Exterior Inspections | 19 | 11/22/08 9:37 AM |
| CPA of Health Canada reminding us of corded window coverings. | gromicko | Canadian Inspectors | 4 | 4/23/07 8:31 AM |
| Vinyl siding window trim | jclark1 | Exterior Inspections | 14 | 6/6/06 10:46 PM |
