What would cause shingles to crack like this? There are several shingles on this roof that is cracked in this manner. The owner states the roof is five years old. Gable and soffit vents only. One power roof fan.
Thanks |
It is a little hard to see the cracks in the photo but check this info on manufacturer's defects:
http://www.inspect-ny.com/roof/RoofWarranties.htm InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
i can only make out 2 damaged, unless you have a lot more of this appearing after 5 yrs
my WAG would be damaged before or during installation ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
I agree with Bob
"I create controversy whether they like it or not" |
I meant Barry sorry Barry
Would he could be a Bob if his parents wanted lol |
LOLOL well we use dynamite here
Bad photo. Barry, there are several cracked shingles. Thanks!
dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Most houses out here, even with our heat, have only gable and soffit vents, if that. Like Bob said, installation. But how was the adhesion and granular holding up. Roofs fail sometimes....and sometimes long before they're supposed to.
Bob who?? "I create controversy whether they like it or not" |
C'mon Carl, just playing off of Wayne'e earlier mishap.
And I am still waiting for the fish to bite!
The shingles may be nailed too high, (installation flaw) or the tar adhesive strip isn't working right (manufacture's flaw). Or the weather's been kind of extreme lately (global ..... bad weather John Kogel www.allsafehome.ca |
Looks like installation problem. Heat usually does not cause cracks. It causes blisters and makes the granuals fall off. If it is a manufacture defect you will usually see it repeats on the run. And is in the same area of the strip. These are laminate shingles and have two layers glued together.
1 does it happen on more than one strip( being the 3 foot long shingle if american style and if metric than a little longer) Repeat 2 does it go thru both layers or just the top. 3 Is in in the same area of the strips if it repeats. |
