rock (ground) brick contact.
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yes and I would also recommend a window well and raise the AC unit.
. Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I agree with Roy Chris, the weep holes in the brick are most likely covered up to.
Is that Lava Rock? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
If they did not create a brick ledge in the foundation two bricks down from the sill plate, they could be having a problem.
I forgot about the weep holes, that is non-existent in residential homes, right.? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
No moisture evident at interior, much of lower level was finished though. Here' a view at right rear corner.
Nice deck framing Chris. Nice bed joint for the brick too!
So I guess weep holes and proper flashing is out of the question EH! LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The deck was *wonderful*
Weeps and flashing are becoming rare in this area, even on new construction. When I find a newer brick veneer home properly flashed and weeped I make a point to praise he builder. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Contractors always like to explain to me why there are not no weep holes in the brick. The number one answer is: If the yard is raised above the weep holes, it will cause water to run into the wall.
I think that a window well is in order as well.
Christian Mettel Certified Home Inspector Aurora, Ontario 289-221-4744 iNachi ID#06022187 www.buildingdetective.ca Aurora Home Inspection |
Depends on where the soil line is in relation to the foundation. Rocks don't hold water, that's why they are used to facilitate drainage. Probe down and see if there is soil covering the the sill plate area. If there is, then there might be a problem. Can't make any more comments without additional information.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Please tell me that you call it out.
The deck, or lack of weeps and flashing?
| Cell Phone Do not call #'s | bjones5 | Canadian Inspectors | 10 | 1/31/09 12:17 PM |
| Last Call for INSPECTVUE SOFTWARE DISCOUNT $845.00 includes Tax...... | jwatts1 | Inspection Hardware, Software & Publications | 4 | 8/8/07 10:47 AM |
| Last call for 2006 pricing for Inspection Management Systems from TheScheduleCenter | gromicko | Miscellaneous Discussion for Inspectors | 1 | 12/20/06 8:22 AM |
