Old 10/2/08, 12:21 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default What would you recommend for this downspout
Yes I know the 6 foot deal , so lets get past that comment.
What would you suggest that would help here.
I would not wish to create a trip hazard, and suppose they capped that drain below , because it emptied into the towns system.
I am thinking the flexible roll out type.
Old 10/2/08, 12:27 PM
mnahrgang's Avatar
Default Re: What would you recommend for this downspout
Attachment 24368
I'd recommend dumping a bucket of water down it to see what happens with the drainage. If it puddles next to the foundation, then (based on the picture) I'd recommend an elbow to shoot it away. If it drains away, then I wouldn't recommend anything.
Mark Nahrgang
www.HeyMark.info
Old 10/2/08, 1:40 PM
relliott's Avatar
Thanks
The sidewalk is vaulted away from the foundation.
It is common to see this situation , but just saying to direct it 6 feet away is sure easier than giving a real solution.
I hate deferring or passing the buck.
I also think of winter and freezing rain
Old 10/2/08, 2:03 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Is that the reason the underground drain is plugged or is it just stopped up? Ideally, cleanout that underground drain, but lacking that and given slope away I would recommend nothing. They could breakup the sidewalk and run it under, I guess their not open to sledge hammers and concrete mixers (oh well).
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 10/2/08, 2:41 PM
jkogel jkogel is offline
They could cut a trough with a concrete saw, not that hard. I think they want to direct water to the left side of the walkway there, so it would need to be a shallow open drain with a grate.
The other way would be ugly, pipe the water along the wall to the back of the house.
John Kogel
www.allsafehome.ca
Old 10/2/08, 2:51 PM
James F. McKee's Avatar
Bob...in the picture it looks like the one next door is still going underground....this may just be someone didn't want to pay to clean the drain out...I'd try that first if it was mine,...jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 10/2/08, 3:29 PM
relliott's Avatar
There are four of them with one right by the back door going into the pipe , but I have a feeling the town forced them to be closed.
Good suggestion to have them check with the AHJ though.
Old 10/2/08, 5:36 PM
Christopher Currins's Avatar
Going by age of building, my guess is the underground drain is clay (ceramic) and is cracked, broke. Was there any evidence from inside basement wall of previous water damage or repair?
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 10/2/08, 5:42 PM
relliott's Avatar
No but many towns may not want it draining into the public system.
Looks like 1952 using the proven toilet top method
78 page report on this one (empty)
Old 10/2/08, 6:13 PM
I was assuming it had a separate drain. We have a lot of old clay drains, but most are connected to storm water drain lines, and many are cracked.
That's a lot of report, I hope you got paid double.
Christopher Currins
Certified, Licensed
Old 10/2/08, 7:17 PM
Bob, those look like 2'x2' concrete dry set pavers, could those be removed and go underground to a French Drain away from the building?
Just a thought when I saw those pavers.
Marcel
Old 10/2/08, 8:46 PM
relliott's Avatar
Marcel
Hi Marcel
Yeah but this is a foreclosure with lots of big ticket items to fix and I figure the easiest solution would be appreciated.
It is common in Chicagoland to have sidewalk against side walk.(small lots you know)
Old 10/2/08, 8:49 PM
David A. Andersen's Avatar
Its a slab, and I see no other issues.
I'd just tell them to monitor it.
BPI# 5015804
Old 10/2/08, 8:51 PM
relliott's Avatar
Wrong
Slabs are only for garages around here.
Garden unit is rental.
Old 10/2/08, 9:01 PM
Bob, I looked at your picture again and notice there is another downspout in the back of the same building and also one mid stream of the walkway on the adjacent building.
Is it possible that is why they used 2'x2' walkway concrete pads with those big gaps to dissipate the water from the gutters?
They might have back filled with all stone and it is not a problem at all.
I'm speculating here, but hasn't this been like that for how long and worked?
Marcel
recommend engineer or not jjones2 Structural Inspections 11 4/14/08 7:15 AM
Downspout needed dmacy Exterior Inspections 3 1/30/06 12:20 AM
