Old 4/8/10, 11:40 PM
ejones2 ejones2 is offline
Default How would you write this up?
I have writers block its too late. How would you write this up?
would-you-write-up-easter-2010-002.jpg   would-you-write-up-easter-2010-017.jpg
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/9/10, 8:06 AM
Default Re: How would you write this up?
Simply state the issues you observe...... improper grade around the concrete slab as well as downspouts not properly draining away from home resulting in erosion around (name the area). Recommend that a professional landscaping contractor correct same which includes pushing gravel back under the slab (poor job on the slab by the way however based upon my experience I don't foresee it failing). The downspout should be cut and the elbow repositioned and/or install drain pipe extensions on same.
Was the concrete slab recently poured?...... wondering if they were using bricks and other objects as a filler
I would also recommend that those type of thresholds be properly caulked underneath and properly supported....if not they end up separating from the brick moulding which will eventually deteriorate. Also check to see if they actually caulked between the brick mould and threshold......most of the time the installers mistake adhesive for caulking.
what is that sticking in the concrete?
Old 4/9/10, 8:09 AM
Slab undermined. Repair, as needed, to prevent damage.
Larry Kage, CMI
231 929 3525
Old 4/9/10, 8:31 AM
Banned
Looks like the brick was part of the crushed stone base,
In the upper right of the 2nd photo? Looks like a bit of brick veneer..... supported on a brick ledge or properly attached angle iron, I hope.
Old 4/9/10, 9:37 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like it could be expansive soil. If it is the sidewalk should not be attachend to the structure.
www.MauiHomeInspections.com
No AFCIs for living areas...time to write it up? jfunderburk Electrical Inspections 18 2/2/10 2:35 PM
How do you write up an open neutral mnahrgang Electrical Inspections 7 8/4/08 8:08 PM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 126 4/27/07 11:05 AM
How should I write this gporter Exterior Inspections 11 4/15/06 9:39 PM
