Old 3/24/10, 8:01 PM
Chris Glochau Chris Glochau is offline
Default how to write this up
Hello everyone newbie here and wasn't quite sure if this warrents a look at by a SE. The seperation is up to 3/8" in spots. There is an old drainhole in the middle of the patio so water has been directed under the slab.
Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/24/10, 10:23 PM
Carl A. Brown's Avatar
Default Re: how to write this up
The grade is to high for the structure.
Old 3/24/10, 10:51 PM
Jeffrey R. Pope's Avatar
Not an issue for a Structural Engineer.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/25/10, 8:26 AM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
Carl the house is to low for the grade
Bill Boerner
STL Home Inspection Services LLC
Serving St. Louis/Surrounding
(314) 805-2137
office@stlhomeinspector.com
http://www.stlhomeinspector.com
Residential, Commercial, Radon, Termite, Lateral Sewer Scopes
Old 3/25/10, 8:41 AM
jplecki jplecki is offline
Where is this in relation to the finish floor? based on your pictures (1) it seems as though there is 4 to 6 inches. Is this a slab on grade? no crawl space or basement? Is the water pooling in this area? Normally with slab on grade a deco-drain is used.
John Plecki
InspectPro of Florida
inspectproflorida@yahoo.com
Bonita springs, Florida
Old 3/25/10, 9:51 AM
The patio is 4-6" lower than the finish floor which is slab on grade water is directed away from the house so no evident water damage. There is a drain in the middle of the patio which just drains under the patio.
Old 3/25/10, 12:44 PM
Hope you are doing well Billy.
Old 3/25/10, 1:59 PM
By the way Chris, what part of the world are you in?
No AFCIs for living areas...time to write it up? jfunderburk Electrical Inspections 18 2/2/10 2:35 PM
How do you write up an open neutral mnahrgang Electrical Inspections 7 8/4/08 8:08 PM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 126 4/27/07 11:05 AM
Write It up or not? thejnicki Electrical Inspections 5 8/7/06 3:49 PM
