gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hello to all,
This window install doesn't look correct to me. I plan on writing it up for improper sealing. Is there another way you guys would write this up? Improper install? I kinda think it looks improperly set. Or do you think it just needs to be sealed? Thanks in advance! Regards, |
Gregg; besides seeing a lousy caulk job, the aluminum windows sometimes come with a built in j- channel for the siding material, but I am only guessing, which I should not do, but if that is the case it was a bad caulker installer. ha. ha.
It appears the the window installation might not have been installed per Manufacturers Installation instruction and would reccomend a reputable Contractor to follow up on the installation. Marcel Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks Marcel,
Good to see you here btw. |
Marcel is correct, that window is a new construction window that has the J channel built in, this is usually to accept vinyl siding which would have a profile of 3/4 " not to say that it can't be installed and have wood siding or trim around the window but the finish is poor at best.
Thank you both, I will suggest a re-install or a new window.
| Window well finishing | rmuller | Interior Inspections | 7 | 5/10/07 9:11 PM |
| Tidbits from the ASHI Message Board | jbushart | Miscellaneous Discussion for Inspectors | 124 | 4/27/07 12:05 PM |
| CPA of Health Canada reminding us of corded window coverings. | gromicko | Canadian Inspectors | 4 | 4/23/07 8:31 AM |
| Window installation | jmichalski | Exterior Inspections | 17 | 1/24/06 10:42 PM |
