New (built in 2007) house. 5,700 SF. 2.9 Mil sell price.
BUT. One, original builder (i.e., money guy who paid for the build), 3 GCs on the project (the first 2 were fired). 4 masonry subs (but that has nothing to do with this issue). 1. Full, front view of the house. 2. Close up of the problem area (of which there were two areas, but this is represtative. What's the problem. Who ist at fault. $34,000, so far, of repair costs. Who should pay? Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Will,
I feel stupid, but I can't see anything in the brick. B Bruce Thompson Professional Inspector, Lic. #9199 Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area. www.TylerHomeInspector.com NACHI 06081394 |
Is the defect clear in these photos? Looking for my glasses.....
Lack of proper downspouts on the gutters causing fascia board and other water damage?
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
Wooden frame, with stone veneer (silly, in and of itself
The problem does not have to do with the exterior wall covering. I am sorry for the small pics, but that is the board limitation. Just look, at both pictures. Like you were doing a walk around. Hint: Think about how it would look during a cold, wet winter. 2nd hint: Total of 5 furnaces (all cat 4). Three in the basement and two in the attic. look and think Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Lack of ANY downspouts. in large areas. Where are the downspots. But not the full understanding. Look harder and think. What is the roof SF? Where does the water go? What is its flow pattern? What would this house look like in the winter? No fascia damage (at least not yet). 3rd hint. What style of counter flashing? Especially look at the two areas on the sides of the front doors. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
D'oh! Too late
Dang! I was going to say that, but I thought they were behind the corners. Good call Mike.
this was fun. put something else on Will. Bruce Thompson Professional Inspector, Lic. #9199 Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area. www.TylerHomeInspector.com NACHI 06081394 |
No weep holes, trapping moisture?
According to NACHI education one square inch of downspout handles up to 100 sq feet of roof.
How the steep slope factors in is a formula I recall seeing somewhere,but do not have it off hand to post. How does the number of Furnaces factor in? |
The roof surface, at the front, was about 2000 SF. All draining to little gutters at the front.
The turret gutters had no sownspouts, just open ended and draining to the lower roof. And, notice, from the original picture, that there were small (maybe 6 SF) roofs over the lower windows. No gutters. The two areas on the sides of the front door, had the grade high. There was water coming over the foundation wall in the unfinished basement area at the front. Sill plate was saturated. The builder sent a couple of guys. They caulked the stone / foundation wall interface, after pulling out the weep wicks. BUT, those small windows, on the first floor, had limestone sills. No flashing under those sills. So, the water was running over the gutters (which were WAY too small for the roof SF) and it was pouring unto the small roof section at the 1st floor, then running, directly, onto the limestone sills. There, it penetrated and went down, between the stone veneer and the Tyvek over the wooden sheathing, and then into the basement (Bad flashing at the base, confirmed by drilling a hole in the sheathing, just above the sill, and putting a Rigid See-Snake in). So, some bad workmanship (the base flashing AND the bad repair attempt), but also an Architect defect (for too small gutters draining sich a large area. I would advise that more HIs ge some training in building science. Then you can do consultations for owners and builders and subs. More business, and revenue, but with less work and hassle. Work smart, get paid more, do less work. That is how to survive these tight times. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Diane Pashley is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would like to have so much money ... why always the others !?
| Picture with text software? | bforeman | Inspection Hardware, Software & Publications | 5 | 2/16/09 12:24 PM |
| www.FireDoorInspector.org | gromicko | Commercial Inspections | 108 | 1/12/09 2:39 PM |
