Would this be considered acceptable for the 6" step up?
Small entry area between garage entry door to kitchen. |
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
David, what exactly is the question? I see three risers in the picture.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
As opposed to what? An elevator?
I thought a 6" curb (step up was required at the garage entry door) for gas vapors.
My question was based on the entry from the garage door that had about a 1 inch curb then went through an entrance way, up the steps to the kitchen. I was just curious if there was no entrance way and the door with the 1 inch curb went straight to the living area would this be an issue. I see walk out stairs from basements or splits all the time and obviously there is no 6" curb. |
David, in this area, some jurisdictions will require a 4" step up, but most everywhere, it is not required.
My home is a tri-plex and my garage is flush with my Rec. room on the way in. All depends on the jurisdiction. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Step crack leading to further cracks | gmendes | Structural Inspections | 5 | 6/21/07 10:40 AM |
| step down to garage? | rjennings | Interior Inspections | 30 | 8/3/06 11:34 AM |
| Step cracks in stucco on block home | dbucknavich | Structural Inspections | 1 | 5/19/06 7:53 PM |
| Step flashing at vertical wall? | jlybolt | Exterior Inspections | 31 | 2/12/06 11:40 AM |
