Yesterdays inspection, I found this device stuck into the drain tube for the washing mashine. No washer on site, just this. The plastic drain line went down through the floor into the crawlspace. Was attached to the bottom of the floor joists, it ran about half way across the crawlspace then was just hanging there. Does anyone have any idea what it is ? Thanks in advance for any info..........................Rick
Rick Slocum NACHI # 04072697 Elizabeth CO 80107 ABSOLUTE Home Inspection Service |
Ah a CO man, so I'll ask, was there an "air washer/Evap cooler/swamp cooler"?
tom |
Looks like some sort of air gap at the end of a drain line. I like the swamp cooler line of thinking.
Nope, no swamp cooler or anything like that. This line camr from the crawlspace. The furnace and evaporator coil was down there, but it was at the other end of the crawl from where this line was. There was a condensate pump down by the furnace but it wasn't being used. Not sure if it was t*ts up or what. The condensate drain was dumping right on the ground in the crawlspace. But thats a different issue. I just was wondering if anyone had seen this type of device before. The line didn't run to any piece of equipment, it just stopped about 20' away on the underside of the hoists. WEIRD!!
It's the notorious "Thing-a-majig" that everyone's wife refers to and we just can't figure out what the hell they are talking about.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
maybe a vent of some kind. i have no idea, just a guess.
Was there an air conditioner close to where the other end of the mystery tubing went to under the crawlspace? I'm thinking it might be some home made contraption from a condensate pump or something.
and if there is no water softener, it probably was for the condensate pump...
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Michael,
Good research! That's what it looked like to me but I hadn't seen the one in the pic before. Here is one I came across on a recent inspection used for the water softener discharge. |
Ding, Ding, Ding!
Give that man a cupie doll! Good job Michael! |
Brian,
Don't you have to go bore a hole in some exterior stucco now? John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
