Go Back   InterNACHI Message Board > Specific Inspection Topics > Interior
Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera.
Old 4/24/08, 1:19 AM
lolsen lolsen is offline
Question What is this from
I am doing a reno on a revenue property and there is something that is not right in this house.
1. There is black stuff on the ceiling in the kitchen
2. There is a grease like substance on the lights
3. There is black stuff around the windows. (all windows)
4. There is 2 circles on the screen in the kitchen. (most likely from a fan)
Any Ideas of what is going on????
PS. This is the reason I am at the place
Thanks
Lawrence
Old 4/24/08, 2:50 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Default Re: What is this from
To summarize: POOR HOUSE KEEPING!
You probably nailed it right on the head in your description of one of the pictures. It's probably grease build up. It is imposible to say for sure without actually being there though. Get a good degreaser product like 409 or Fantastic and have at it! If it is really bad on painted surfaces, you might have to encapsolate it after cleaning as much as possible before repainting. Kilz and Zindzer work wonders, but the surface can't be slick. The ultimate fix would be to replace any damaged surfaces, but that can become unrealistic in most cases.
Scrub-A-Dub-Dub!!!
Old 4/24/08, 10:51 AM
Thanks Scott
I was wondering the same but also wondered if it had something to do with drugs??????
Lawrence
Old 4/24/08, 5:29 PM
Brian Jones's Avatar
Brian Jones Brian Jones is offline
Send a message via MSN to bjones5
Say no to drugs. Like Scott said, poor housekeeping. You have cooking fats all over the place mixed with fly poop.
Poor ventilation in bath and kitchen. Put in a high quality bath fan and a high quality range hood/fan and add in some proper house-keeping habits as well as a diet change and the reduction in mess will be very noticible.
Brian Jones
To all newcomers,
"Ceade Mille Failte"
(Gaelic for "A Hundred Thousand Welcomes")
'If we wait for the moment when everything, absolutely everything, is ready, we shall never begin.' - Ivan Turgenev, novelist, poet, playwright
Old 4/25/08, 2:19 AM
Thanks for the replys
It was pointed out to me today that there is no range hood
Also the hot water heater was leaking and the floor sloped away from the drain and into the bathroom.
Renters are great
Lawrence
Old 4/25/08, 2:37 AM
ccurrins's Avatar
ccurrins ccurrins is offline
Please Note: ccurrins is a non-member guest and is in no way affiliated with InterNACHI or its members.
Cigarette smoke ??
Old 4/25/08, 8:13 AM
Poor ventilation in bath and kitchen. Put in a high quality bath fan (low sone model on a feed separate from the light (code requirement) and install a crank or electronic timer to control it) and a high quality range hood/fan (Again low sone and properly ducted- not just 4" diameter "dryer" duct but 5,6,7" metal) and add in some proper house-keeping habits as well as a diet change and the reduction in mess will be very noticible.
Still see cheaper fans even in higher end houses. Did a first year warranty inspection on a $1.5 million house 2 years ago- none of the 5 bathroom fans met codes and 1 was dead.......at 11 months. That was the smallest of the house problems!!!
Less than 1 in 75-100 houses I've inspected have good or even code ventilation systems!!
Old 4/25/08, 9:48 AM
Scott Widick's Avatar
Scott Widick Scott Widick is offline
Send a message via MSN to swidick
Did you say smoke? Here is a partially cleaned wall...
Old 4/25/08, 11:20 AM
Originally Posted by ccurrins
Cigarette smoke ??
Some Cigarette smoke in this house but cooking smoke and grease is the biggest problem.
Lawrence
Old 4/25/08, 11:36 AM
pdoane's Avatar
pdoane pdoane is offline
Please Note: pdoane is a non-member guest and is in no way affiliated with InterNACHI or its members.
Cigarette smoke ??
Exactly what I was thinking,... poor housekeeping and heavy smokers. Cigarette smoke tar will leave a yellowish, sticky film on every surface, including ceiling, walls, light fixtures, etc. Last picture is an obvious plumbing leak with mold.
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
