Old 12/12/07, 10:39 PM
Nick Gromicko's Avatar
Default Advanced tips for inspecting stairways. Please proof...
http://www.nachi.org/stairways.htm
Find a Home Inspector
Old 12/13/07, 10:50 AM
klott's Avatar
klott klott is offline
Default Re: Advanced tips for inspecting stairways. Please proof...
One thing that jumps out is the riser height, it should read maximum 7 and 3/4" not least, I will read further. It shold also read t"The nose is Incorrect", instead of in correct.
Old 12/13/07, 11:10 AM
Kenneth, good catch. Near the bottom of the document I've included your website. OK?
Old 12/13/07, 11:44 AM
klott's Avatar
Great, glad I can help. Thanks
Old 12/13/07, 1:44 PM
rnewman1 rnewman1 is offline
Send a message via Skype™ to rnewman1
I would add to the illumination part that you have to be able to activate the lights without stepping onto the stairs.
Old 12/13/07, 4:06 PM
There are several places that use terms like "stairway which" that should be changed to "stairway that". etc.
I can send them to you if you wish.
Abraham Lincoln
Old 12/13/07, 4:21 PM
Cool Blaine, post them here or send them to fastreply@nachi.org Either. Thanks!
Old 12/13/07, 4:26 PM
Jeffrey R. Pope's Avatar
I sent this via email, but I don't know if it was received.
Currently reads;
Determine if it is continuous. The handrail should be continuous for the full length of the flight of stairs. Measured from a point directly above the top riser to a point directly above the lowest riser of the flight. (The use of a volute, starting easing, or turnout can be installed over the lowest tread.)
Should read;
Determine if it is continuous. The handrail should be continuous for the full length of the flight of stairs, measured from a point directly above the top riser to a point directly above the lowest riser of the flight. (The use of a volute, starting easing, or turnout can be installed over the lowest tread.)
This paragraph is repeated twice in the document, with the same error in each occurrence.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/13/07, 4:32 PM
Sent to fastreply.
Abraham Lincoln
Old 12/13/07, 8:40 PM
Jeff, Blaine... thanks!
