Old 11/8/11, 11:08 AM
Joe Funderburk, CMI's Avatar
Exclamation Anything wrong with ceiling joist hanger?
This is only an exhibition, not a competition.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/8/11, 11:28 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
Default Re: Anything wrong with ceiling joist hanger?
Wrong size and wrong nails. Double wammy on this one.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/8/11, 11:38 AM
Enlighten us on the nails.
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/8/11, 12:02 PM
KEVIN WOOD's Avatar
We have a section on this. I cannot tell what kind of nails were used but they are pulling out from the beam. Either there is allot of weight in this area or the nails are not proper 10d.
http://www.nachi.org/home-inspectors...-fasteners.htm
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/8/11, 12:07 PM
Kevin, why do you say the hangers are the wrong size?
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/8/11, 12:13 PM
Jeffrey R. Jonas's Avatar
You are calling these "ceiling joists". Where is the ceiling they are supporting? What type of ceiling? Need more info.
Old 11/8/11, 12:16 PM
KEVIN WOOD's Avatar
Standard hanger in Canada must be the same size as the joist. Most hangers here have 4 nail holes on the beam and 3 nail holes on the joist. Like the picture in the training on fasteners.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/8/11, 12:17 PM
Sheetrock ceiling was cut away. They modified the structure by installing a beam to carry the load where once there was a wall.
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/8/11, 12:24 PM
Right off the bat...
I would like the bottom edge of the joist to be flush with the bottom edge of the beam. What is that, a 1/4 inch difference? Gonna have a few issues with that.
Can't clearly see markings on nails, but they appear to be okay, except they are drive in at a bad angle.
Bracket appears correct for size of lumber. Question is, is lumber of proper size for the situation.
(Canada doesn't apply in US, so no comment).
Old 11/8/11, 12:46 PM
I'll answer my own question. See page 8 and 16 of this document labeled "double shear nailing":
http://www.strongtie.com/ftp/catalog...09.pdf#page=38
Those nails with a "10" on the head are only 1.5" long. They do not penetrate the joist into the beam. A 10d or 16d nail is required for double shear nailing. A COMMON defect. Look carefully the the nails in the shear holes!
I confirmed that the shear nails did not penetrate the joist because there was a gap I could look up through at several joists.
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/8/11, 1:06 PM
KEVIN WOOD's Avatar
You cannot tell from your picture if it has been nailed correctly.
Good observation Joe.
Did you also notice that they shaved the joist to make the hanger look OK for this application.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/8/11, 2:16 PM
If you look closely, you can see "10" on the nail heads.
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/8/11, 2:17 PM
What is the point of shaving the joist?
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/8/11, 3:24 PM
Bruce A. King's Avatar
You have to know the loads.
You can use hangers with 1.5 inch nails if the application is within specs.
Its .64 times the table value of the hanger.
Just because you see a double shear hanger does not mean it has to be used for that particular location and does not mean the maximum nails have to be used in it.
Here is more information:
http://www.strongtie.com/products/co...rs/LUS-HUS.asp
http://myconco.com/ComEngProb.html
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 11/8/11, 3:56 PM
Not on the shear holes you can't. They don't even penetrate the joist, much less sink into the beam. The manufacturer has a big X over an illustration showing 1.5" nails at the double shear location.
Theodore Roosevelt
Joe Funderburk, CMI
Drilled Joist William Faust Structural Inspections 5 3/12/11 8:39 PM
Free Books And Articles For Electrical jtedesco1 Electrical Inspections 14 1/6/08 6:45 PM
Case Study - Rim Joist Insulation Problems wdecker Thermal Imaging, Infrared Cameras & Energy Audits 5 12/20/07 2:47 PM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 4 1/22/07 12:24 PM
