I know the only way to be sure is to test, but does anyone have information regarding Johns Manville "Spinusaltion" containing asbestos?
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Since it is a mineral fiber, first produced in the late 50's, there's a good chance that it contains asbestos.
This is the first time I have heard of asbestos being found in a batt style mineral fiber insulation insulation. Have you ever had any tested and verified for asbestos?
It says fiber glass on the batts fellas.
Quite right - I didn't really look that close.
I remember the brand name (Spinsulation) from a conversation years ago. The brand name was trademarked from (roughly) 1962 to 1985, and the original product was a mineral based fiber, which was told to have contained traces of asbestos. The product was discontinued (to the best of my knowledge) shortly after ACM's were prohibited in residential construction. I would be very curious to know if this insulation is the same stuff. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 10/31/10 at 6:56 PM.. |
Products from the Johns Manville name included asbestos paper, block insulation, cement board, cements, cloth, electrical products, gaskets, felt, floor tile, packing seals, pipe covering, piping, roofing products, siding and wallboard. The company also supplied the raw fibers. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Asbestos paper was used as pipe wrap.
Guess what? Johns-Manville manufactures fiberglass!!!! I worked at their Willows, Ca. fiberglass manufacturing plant back in 1980.
Copper pipes were not used mainly in homes until the mid 60's. How old is the home? Appears to be fiberglass insulation. Yep.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
| Asbestos.............What is asbestos? | mkyriacou | Ancillary Inspection Services & Additional Topics | 2 | 9/17/09 5:03 PM |
| Asbestos | jmckenna1 | Miscellaneous Discussion for Inspectors | 0 | 1/26/07 11:11 PM |
| Asbestos | jmckenna1 | Miscellaneous Discussion for Inspectors | 0 | 1/26/07 11:09 PM |
| Is this a competent asbestos removal job? Is our basement now a biohazard? | David Paterson | Ancillary Inspection Services & Additional Topics | 5 | 1/16/07 7:16 PM |
| Mould v. Asbestos | Caoimhín P. Connell | Ancillary Inspection Services & Additional Topics | 30 | 1/15/07 10:35 PM |
