Hey Folks-
Is asbestos cement-based siding considered a fire-rated material and would suffice as a firewall? This property had what appeared to be asbestos cement-based siding. They later attached a garage and left the material on the inside wall of the garage toward the house. The interior wall has a couple locations where the firewall is compromised. But if it wasn't compromised and the asbestos cement-based siding was solid all along the interior wall, would you consider it an acceptable firewall separation? Thanks Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I'm not sure if I would be to concerned about the siding. I would however be concerned about the wood storm door, the original wood jamb it is installed on and it appears to me a wood door behind it? Hard to tell in the picture. Also any other penetrations in the parting wall that you mentioned.
The door is not rated so start there.... |
I agree. But I'm still curious about the details: 1. Would you consider this interior wood door fire-rated? It meets the 1-3/8" but I don't think the glass meets the requirements...but I'd prefer confirmation on that. 2. If the interior door is fire-rated is it okay to have the wood screen door? 3. And I'm still very interested on the acceptability of asbestos cement-based siding as a firewall. Thanks! Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
There is no U.L. Assembly listing for fire rated separations using that product, so it would now be just considered a non-combustible separation which has no rating.
There is a window breaching the assemble, a wood screen door and frame as others mentioned and part of the gable end louver opening in the attic of the garage. which would be OK only if the garage ceiling has at least a 1/2" drywall and sealed. Check with the local AHJ to see what is required in your area. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
But in reference to the siding (and I'm just discussing here, I wouldn't put this in a report), from a practical standpoint the siding is probably a better material to withstand a fire than drywall, yes? But from a technical standpoint since it has no U.L. listing as a fire-rated material it does not meet the requirements...is that fair to say? Rigler Home Inspections Hays, KS 67601 785-656-0272 |
That is correct Kenny, and don't forget, we don't know if it is asbestos siding until tested, But I installed some of the stuff as a kid and I will tell you it was the best siding ever invented and it won't burn. I bet it would compare to the 20 min. that a 1/2" drywall last in a fire.
P.S. They also make a matching siding now for repairs manufactured by GAF;
See here; http://www.squidoo.com/ResidentialSiding LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I agree with Marcel. The siding would probably be OK for a firewall protection but with all of the other penetrations in the wall it"s kinda of a mute point.
As far as the door goes, I would say no way, it should be fire rated with self closing hinges. I would point it out as a safety hazard which I'm sure you did. Good discussion, thanks! |
Also, I can see broken tiles in the picture..... My parents house in California built in 1945 or so is still sided and the garage still roofed with the same material. |
WHy would you be worried about it being a firewall. The whole house will never meet todays standards. Just write it up as so and move on..
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I would at least check and see what is necessary to maintain a separation that will comply with, at a minimum, of State or Local requirements.
Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 Last edited by krigler; 4/19/10 at 8:52 AM.. |
It would have to meet code as far as a burn rate goes. I think fire rated drywall has a 90 minute burn rate.
Other material can be used, say if it's existing but I think fire rock is the standard we use now. |
| Hard board siding? | sfalvey | Exterior Inspections | 23 | 11/29/10 2:41 PM |
| Asbestos.............What is asbestos? | mkyriacou | Ancillary Inspection Services & Additional Topics | 2 | 9/17/09 5:03 PM |
| Help! Asbestos Pipe Insulation | John Doem | General Inspection Discussion | 24 | 6/3/08 9:59 AM |
| Asbestos | jmckenna1 | Miscellaneous Discussion for Inspectors | 0 | 1/26/07 11:11 PM |
